Home > Technical (L322) > 4.4 TDV8 coolant temperature sensor
dirtymonkey38
Ok, so over the weekend I replaced the oil cooler gaskets and oil pipe o-rings. Topped up the oil and coolant and run the engine. All good, however the temperature on the digital dash is permanently in the middle. Left it over night, cold engine and the gauge is still in the middle. Heaters are working fine and getting hot. Can anyone tell me where the sensor is located so I can check it’s plugged in (assume it is it there would be no reading at all?) and check wiring. May have to replace the sensor so any help would be good. 2011 RR Autobiography 4.4 TDV8
Post #472358 13th Mar 2018 10:03am
Baltic Blue
Number 5 in this picture.
Post #472365 13th Mar 2018 10:46am
you're our official 'mike-crocat'
Mr. Green Wink ... - .- -.
Post #472366 13th Mar 2018 10:48am
dirtymonkey38
Many thanks. Is that block hiding under anything? 2011 RR Autobiography 4.4 TDV8
Post #472367 13th Mar 2018 10:49am
Baltic Blue
I hope that does not make me a Russian enemy Rolling with laughter G reg 2.5VM Vogue Portofino red 1991- 1999
Post #472368 13th Mar 2018 10:51am
Baltic Blue
Thermostat housing is No.6 in this picture.
Cheers
Mike G reg 2.5VM Vogue Portofino red 1991- 1999
Post #472369 13th Mar 2018 10:54am
dirtymonkey38
Buried then. Hopefully I can get my hands in 2011 RR Autobiography 4.4 TDV8
Post #472370 13th Mar 2018 10:59am
Baltic Blue
Just found another reference.
Post #472378 13th Mar 2018 11:23am
dirtymonkey38
So looking at the front of the engine, where do I need to look. Attached also are IIDTool screen grabs. Assume it’s the sensor at fault.
Post #472379 13th Mar 2018 11:27am
dirtymonkey38
Hopefully all sorted now. some dipstick (me) didn't plug the sensor back in. Embarassed 2011 RR Autobiography 4.4 TDV8
Post #472433 13th Mar 2018 4:43pm
nino_nino
Stan you're so right, Mike is resident PDF expert and such an asset to have. Thanks Mike Bow down
Nino,
Post #472438 13th Mar 2018 5:14pm
dirtymonkey38
Is Mike Baltic blue? Thank you for the pictures, they were really helpful. Much appreciated. 2011 RR Autobiography 4.4 TDV8
Post #472440 13th Mar 2018 5:30pm
Mike is indeed Baltic Blue... Thumbs Up ... - .- -.
Post #472444 13th Mar 2018 5:41pm
Baltic Blue
Embarassed Embarassed G reg 2.5VM Vogue Portofino red 1991- 1999
Post #472450 13th Mar 2018 6:00pm
