![]() | Home > In Car Electronics (L322) > No TV image |
stan Site Moderator Member Since: 13 Jul 2010 Location: a moderate moderated moderator moderating moderately in moderation Posts: 35771 ![]() ![]() |
move FF to a different location?
Beemergriff Member Since: 06 May 2016 Location: Northamptonshire Posts: 62 ![]() ![]() |
Thanks Stan. I have tried in 3 different locations, with no noticeable change in results.
there are two signal amps underneath the windows in the cubby boxes, maybe one of them is faulty..
paulbrown22 Member Since: 23 Dec 2017 Location: London/Poole Posts: 358 ![]() ![]() ![]() |
Antenna amplifiers as Stan points out are already fitted in the rear load space side compartments . One of mine seemed to have a snapped connection though when I bought the vehicle, so I had to repair that. My whole tuner unit then turned out to be dud, so I swapped it out with a cheap Ebay job, and it then sprang into life. Worth checking all the connections are correctly fitted, clean, etc. - if you don't have RSE, is very easy to remove the tuner/connections for inspection.
Thanks for the advice, and I will start by checking that all the connections in boot funny holes are good |
