![]() | Home > Technical (L322) > Air Suspension Fault Help |
| nicedayforit Member Since: 11 Jun 2011 Location: Beside the Solway Posts: 3989
Air tank pressure sensor or connections to it? |
| Joe90 Member Since: 29 Apr 2010 Location: Hampshire Posts: 6434
"2 x yellow light on control switch - centre and round switch."
| RR1994 Member Since: 10 Mar 2018 Location: london Posts: 8
nice day for it and Joe - Thanks
I presume you have tried pushing in the round switch 3 to switch off the inhibit suspension function? |
| m@ttsFF Member Since: 12 Dec 2017 Location: Surrey Posts: 338
You’ve closed the doors when testing , right? P525
Um, 1 is not a light it is a switch, so I presume you mean 2 the middle light for normal height?
Hi all,
I’d be looking to upgrade the ECU with BT IID tool . Sounds like the re set caused the issue P525
@ m@ttsFF
| All times are GMT |
