Home > Maintenance & Mods (L322) > Heater blower advice - 2011 Autobiography
Speedster356
United Kingdom 2011 Range Rover Autobiography TDV8 Alaska White
Hi all, just registered but been an avid reader of all the expert advice for a few years. I've just upgraded from a 2003 TD6 Vogue to a 2011 TDV8 4.4 Autobiography.
I need some advice - the front heater fan stopped working today. All the controls seem to work and I can feel Heat through the vents when moving, so looks like it's the blower. I know about the FSR issue on earlier models, but is this still the case with the later 2011 vehicles?
Any help greatly received.
Post #472739 15th Mar 2018 9:54pm
GGDR
Congrats! Pix pls!
Your knob's got two leds in the middle - one's for auto temp and the other's for auto fan.
Do the the LEDs around the knob light up when you crank up the dial? This turns auto to manual and the centre led will turn off.
Let us know...
. Cheers, Greg
Post #472743 15th Mar 2018 10:07pm
Speedster356
Thanks for the quick reply. I'll get some pics loaded in the My RR section.
All the controls appear to work fine in both manual & auto modes - so all the right lights come on - just no fan blowing.
Post #472744 15th Mar 2018 10:21pm
mpirie
Yes, the FSR issues still apply to 2011 models.....at least it did to mine.
I think my FSR failed because the fan stopped cooling it and caused it to overheat, regardless, I had to replace the FSR and the fan.
One is cheap and easy, the other is erm ....not!
Mike
Post #472784 16th Mar 2018 9:51am
GGDR
What's an FSR?
. Cheers, Greg
Post #472785 16th Mar 2018 9:57am
final stage resister sir Thumbs Up ... - .- -.
Post #472786 16th Mar 2018 10:06am
Speedster356
Brilliant, thanks Stan. I've got a spare, new FSR already (bought it just in case for my old TD6) so will have a go at changing it today - before the beast from the east returns Very Happy
Post #472788 16th Mar 2018 10:15am
Speedster356
Thanks Mike, I'll change the FSR today & see what happens. I've got a warranty, so the blower motor should be covered if it needs replacing.
Post #472817 16th Mar 2018 2:36pm
Speedster356
Replaced FSR this afternoon and all working OK again - thanks to all who have given the advice & guidance on FFRR forum. At least I'll be warm over the weekend now Very Happy Thumbs Up
Post #472859 16th Mar 2018 8:30pm
bembo449
United Kingdom 2002 Range Rover Vogue Td6 Adriatic Blue
little pokey piece of plastic and metal makes such a difference eh pal Laughing
Post #472964 17th Mar 2018 7:49pm
Speedster356
Absolutely bembo - wish it was as easy with my house heating which packed up last night & won't get an engineer until tomorrow
Post #473006 18th Mar 2018 10:51am
Baltic Blue
Check the boiler overflow drain is not frozen.
Mine was buried in frozen snow this morning.
2 minute fix with gas blowlamp.🌨🌨🌨 G reg 2.5VM Vogue Portofino red 1991- 1999
Post #473012 18th Mar 2018 11:46am
Speedster356
Thanks BB but mine's an outside oil boiler done different setup. Not too much of a problem as I've got the log burner on Thumbs Up
Post #473016 18th Mar 2018 12:13pm
