![]() | Home > Technical (L322) > Headlamp / Headlight Washer Jet - Drivers Side Not working |
JCW Member Since: 13 Apr 2013 Location: Cotswolds Posts: 923 ![]() ![]() |
One pump and located on the nearside, so likely the fluid is frozen on the run to the offside nozzle, once the temperatures rise, if still not working then its blocked, thats a bumper off job if you need to remove the nozzle, theres a spring clip behind the bumper that holds it in place. |
tj2k Member Since: 10 Dec 2017 Location: Shropshire Posts: 34 ![]() ![]() ![]() |
Thanks a mill. So, I had another look before seeing your reply & my guess is the pipe has come off the nozzle & there’s a fluid leak on drivers side when the headlamp washers engage!
Yes, bumper off to remove headlghts on the MY10 facelift.
Baltic Blue Member Since: 13 Aug 2015 Location: North Wales Posts: 3846 ![]() ![]() ![]() |
That really helps - thanks to both of you!
Didn’t need to remove the bumper for this job fortunately, just the drivers side wheel arch cover, sufficiently pulled back enough to allow my grubby mits to reach in & reattach the headlamp washer pipe which had indeed come off. Simply pushed back on & it tested fine 👍
