Home > Technical (L322) > Problem Part 1 (Electrical)
Captain Slog
United Kingdom 2005 Range Rover Vogue Td6 Java Black
Hi
I'm having a problem with the centre console screen and it's associated features.
At periods ranging from a couple of days to over a week when I return to the car I find the screen has no power and none of the associated functions work Nav, radio, phone, CD ETC. The LED power indicator on the on/off switch does not illuminate when pressed.
I have discovered that if I remove then re-install fuse number 49 (30A) labeled 'Navigation system, on-board computer, on-board monitor,audio system' the system will seem to re-boot and display a message on the screen saying a new key has been found and personal settings are being restored. After the re-start the system and all functions work fine.
Some of the systems functions Radio, CD changer ETC have separate control modules but there must be one unit that brings all of the data together and provides this data and power to the screen.
Has anyone seen this problem before? or can anyone suggest a fix or suggest a location for the control module of the screen?
_________________
Currrent: 2005 FF Range Rover L322 Vogue TD6
Gone: 1999 Range Rover P38 HSE TD6
Gone: 1985 Land Rover 90 SWB diesel
Post #47312 24th Jan 2011 7:59pm
it might be as simple as the battery not giving enough power to get ALL the ecu's going...how old is the battery, if over 3 years then i would think about replacing it. ... - .- -.
Post #47318 24th Jan 2011 8:18pm
Captain Slog
Hi
Thanks for the reply.
If this is the case why does the system re-start after the fuse is pulled and replaced the battery voltage will be the same and then why does the system not re-start when the engine is running and battery/system voltage is at maximum?
Surely if a battery can supply enough amps to start a diesel engine in the winter then a few ecu's should be no problem unless it is a voltage issue and the voltage would not change between pulling and re-inserting a fuse.
I can only ever get the system to re-start (when down) by pulling and re-inserting the fuse.
_________________
Post #47323 24th Jan 2011 8:26pm
could be [like a pc] you're rebooting the ecu which in the first place didnt have the oooophh to get going..only a theory mind. ... - .- -.
Post #47327 24th Jan 2011 8:31pm
