Home > General > Which TDV8
JohnnyDangerous
England 2002 Range Rover Vogue 4.4 V8 Java Black
Which TDV8
After 6 years and 130L miles im thinking of getting rid of my 2002 4.4 V8 LPG, what are the thoughts on 3.8 and 4.4 TDV8. Do any have an inherent problem? Which is more tuneable? Anything to look out for on 2010-12 cars. Thanks guys One day your life will flash before your eyes......................................make sure yours is worth watching!
Post #473258 21st Mar 2018 12:42am
Vogue
The 4.4 is the better engine, plus it's got a better 8 speed box, returns higher MPG and in the opinion of many doesn't need tuning as it has so much grunt to start with. My last L322 was a 4.4 tdv8 and it was faultless over 69k miles.
My previous one - not the 4.4, had endless trouble with Brake Callipers needing replacement, there seemed to be issues with the Callipers fitted to the pre 2010 facelift, and this was solved with the 4.4 and larger Callipers being fitted. 2021 L405 Vogue SE 4.4 V8 DIESEL ~ #17
Post #473262 21st Mar 2018 6:42am
Just be careful if you do small and often journeys, as the DPF on the 4.4 might start to give you problems. Got - 2017 SDV8 Autobiography in Loire Blue
Post #473281 21st Mar 2018 9:54am
GAC23
United Kingdom 2015 Range Rover Vogue SE SDV8 Indus Silver
I have the TDV8 and do lots of small journeys.
DPF isn't a problem as long as you do one good 20 min, 40mph+ run every week or two.
Worst case you just do it when the amber DPF Full warning comes on. What do I put here then?
Post #473300 21st Mar 2018 11:39am
JohnnyDangerous
Thanks guys, I have a snap on diagnostic machine so can regen the dpf manually if needed. What is the highest spec? Is it the autobiography? Just missed one with brand new engine from RR done 2K miles, car showing 60 something for 20K. One day your life will flash before your eyes......................................make sure yours is worth watching!
Post #473309 21st Mar 2018 1:02pm
JohnnyDangerous
I need it for towing a shuttle with my GTR in so its a bit weighty and TDV8 grunt seems the sensible way to go.
Post #473310 21st Mar 2018 1:04pm
