![]() | Home > Technical (L322) > TD6 cutting power |
holidaychicken Member Since: 06 Nov 2013 Location: Kent Posts: 1086 ![]() ![]() ![]() |
It’s becuase you are putting petrol in a TD6 |
bembo449 Member Since: 26 Jul 2017 Location: lincolnshire Posts: 809 ![]() ![]() ![]() |
is your MAP sensor at the back of the inlet blocked ?? |
AKIS Member Since: 23 Apr 2009 Location: GREECE Posts: 186 ![]() ![]() |
Thanks guys.Unfo cannot read codes unless i go to workshop.
TomCobbly Member Since: 29 Jun 2016 Location: Guildford Posts: 122 ![]() ![]() ![]() |
Fuel filter perhaps? 2011 4.4 TDV8 Vogue SE
id be tempted to spill test the injectors |
Thanks guys.Following jobs have been done since
You need your codes read or you will on an expensive path of replacing your range rover a piece at a time.
Yes you are right.Can anyone please recommend a code reader (being not expert i donot mind if will not give me the ability to interfere in Ecu as long as will read faults)
Beemergriff Member Since: 06 May 2016 Location: Northamptonshire Posts: 62 ![]() ![]() |
You say you have changed all injectors, but have you looked at the wiring harness to the injectors?
Diagnostics !!
Thanks guys.I will check injectors wire looming to see at least if any visible defect but yday in a trip of abt 400kms car responded without any cutting off inspiteof various experiments i did so to see under what conditions engine is cutting off.
If you remove the top centre cover you will see the thick twisted wiring for each injector, all i nneded to do was touch the wiring gently and the engine would cough, it was injector 3 on mine, new loom and all good. It would even cough if i just pushed the middle cover down a bit |
How to test injectors wiring well noted with many tks
Something else to check is your turbo pipes and intercooler for splits or signs of leaking, the intercooler you can see looking at the front of the car under the bumper.
