Home > Technical (L322) > Adaptive lights
Steveo
Adaptive lights
Good evening all I have just got a 2007 VSE with adaptive headlights and I would like to know how to check if there working ok when I turn them on should they do the calibration movement every time I turn them on or is it once every so many times when I turn the steering the corner manoeuvre lights come on just would like to know if the HID are doing there stuff when there on one is brighter than the other so I have ordered a new set of bulbs when you turn the ignition on the yellow warning light comes on then goes of when started cheers Steve
Post #473504 22nd Mar 2018 10:06pm
dolph34
Ireland 2015 Range Rover Autobiography SDV8 Corris Grey
They do their ' dance ' everytime they come on ๐Ÿ‘ 2015 4.4 AB
GSXR 1000 K5
R1 1998
Post #473506 22nd Mar 2018 10:12pm
Steveo
Hmm might have a problem then as I have only noticed it a couple of times
Post #473507 22nd Mar 2018 10:16pm
Andy_J
Scotland 2007 Range Rover Vogue SE TDV8 Java Black
On my 56 plate (MY2007) they do the calibration test when you start the engine 56 TDV8 Vogue SE
9 Freelanders, 2x 2002 TD4ES, 2001 TD4, 2002 1.8GS, 2000 XEDI, 2x 2000 1.8ES, 2004 1.8 & 2000 1.8 GS (rolled)
91 Lotus Carlton (sold)
90 Lotus Elan (BRG)
Post #473653 23rd Mar 2018 10:32pm
Steveo
I have just had a look and it only dose itโ€™s thing when you start the engine I was thinking it done it when you turn on the ignition
Post #473655 23rd Mar 2018 11:04pm
Steveo, the AFS system takes its data from the Air Suspension along with the gearbox and several other areas... Engine must be started to get this data sir Thumbs Up
Post #473660 23rd Mar 2018 11:40pm
Steveo
Cheers is there also a shutter in the headlights that moves when you select main beam Rolling Eyes
Post #473661 23rd Mar 2018 11:53pm
Yes there is, only moved when full beam is selected from dipped beam, NOT full beam flash as that only works the halogen full beam lights... Thumbs Up
Post #473662 23rd Mar 2018 11:59pm
