|  | Home > Technical (L322) > Lower thermostat modification V8 4.4 M62 2002-2005 |
| doclees Member Since: 24 Jun 2015 Location: PA Posts: 672      | Exactly. Creates the same resistance the heating element creates. The case is a heat sink. | ||
|  7th Jan 2018 5:16pm |
| holidaychicken Member Since: 06 Nov 2013 Location: Kent Posts: 1086      | I think I was getting resistors and capacitors muddled up or something else yet unknown to man   | ||
|  7th Jan 2018 5:22pm |
| doclees Member Since: 24 Jun 2015 Location: PA Posts: 672      | I understand. I have the weakest knowledge of electrical engineering in even the simplest forms. The only lab in physics that I had no grasp of. | ||
|  7th Jan 2018 6:00pm |
| holidaychicken Member Since: 06 Nov 2013 Location: Kent Posts: 1086      | How much did you pay for it ? | ||
|  22nd Mar 2018 11:03pm |
| spgmcb Member Since: 11 Jun 2015 Location: Kent Posts: 17  | £50 posted from Germany on e bay. | ||
|  22nd Mar 2018 11:39pm |
| holidaychicken Member Since: 06 Nov 2013 Location: Kent Posts: 1086      | Thats good as i paid around £100 | ||
|  23rd Mar 2018 8:37am |
| spgmcb Member Since: 11 Jun 2015 Location: Kent Posts: 17  | That may have been a BMW part, Behr makes the BMW parts so I was happy to use their part which turned out to be BMW anyway. It worked out cheaper than the e bay mod with no cutting or leaking gaskets as its fits perfectly, for me also peace of mind using a oem part. | ||
|  23rd Mar 2018 3:01pm |
| holidaychicken Member Since: 06 Nov 2013 Location: Kent Posts: 1086      | Heres mine from earlier in the thread
|  23rd Mar 2018 5:09pm |
| spgmcb Member Since: 11 Jun 2015 Location: Kent Posts: 17  | That's the one, fits perfectly, all you need to do is tape up the wire to the unused heating element and store it under the engine cover. No dash warning lights. | ||
|  26th Mar 2018 11:34am |
| holidaychicken Member Since: 06 Nov 2013 Location: Kent Posts: 1086      | This one ?
|  26th Mar 2018 10:04pm |
| spgmcb Member Since: 11 Jun 2015 Location: Kent Posts: 17  | No, the p and p and cost of that one is a lot more.
|  27th Mar 2018 1:11pm |
| holidaychicken Member Since: 06 Nov 2013 Location: Kent Posts: 1086      | Yep sorry i found yours and then linked the wrong one | ||
|  27th Mar 2018 4:03pm |
| Deltaevo Member Since: 02 Apr 2017 Location: Ashbourne Posts: 39      | Just completed the thermostat mod, used the 88 degree Stat. Engine feels much smoother and a little quieter when idling. My thermostat had packed up anyway was taking ages to get upto temperature. Very happy with the mod, and a big thanks to the people that have posted on this thread. | ||
|  12th May 2018 5:06pm |
| Jmckenzie295 Member Since: 18 Apr 2018 Location: Glasgow Posts: 17      | I am definitely thinking of getting this done. Probably will go with the BEHR as as far as I can see is a straight swap, correct?
|  21st May 2018 10:05pm |
| Posting Rules
