![]() | Home > Technical (L322) > Maf sensor causing dpf full? |
Baltic Blue Member Since: 13 Aug 2015 Location: North Wales Posts: 3863 ![]() ![]() ![]() |
dirtymonkey38 Member Since: 14 May 2017 Location: West Yorkshire Posts: 158 ![]() ![]() ![]() |
Didn’t notice any when I took it apart. It was fine before though so a bit strange. Now I’m getting “water in fuel condition” on my scanner 2011 RR Autobiography 4.4 TDV8 |
stan Site Moderator Member Since: 13 Jul 2010 Location: a moderate moderated moderator moderating moderately in moderation Posts: 35801 ![]() ![]() |
you can drain the water out of the fuel filter by undoing a screw underneath the filter... ... - .- -.
Cam-Tech-Craig Member Since: 04 Aug 2011 Location: Gloucestershire Posts: 16392 ![]() ![]() ![]() |
Any other fault codes? |
Can somebody do me a favour and take some pictures of their intake hoses from above and end on? I’m NOT convinced they are set up correctly and are leaking air causing false readings.
d...m38,
