Home > In Car Electronics (L322) > 2007 vse tv
Steveo
2007 vse tv
Good morning all I have just got a 07 vse with rear seat entertainment can anyone tell me should I be able to watch tv on the front screen or rear screens just I cannot get picture on tv channel it will search but not find any tv channels is this normal or do I need to upgrade to get digital tv picture cheers
Post #473775 25th Mar 2018 8:38am
it could be you are in a bad reception area so move closer to a transmitter or you might still have the old analogue tuner... ... - .- -.
Post #473781 25th Mar 2018 9:16am
Steveo
Is there a way to check what tv tuner I have fitted cheers
Post #473785 25th Mar 2018 9:52am
paulbrown22
United Kingdom 2011 Range Rover Supercharged 5.0 SC V8 Stornoway Grey
You can certainly look at the label on the underside of the TV tuner unit which will tell you exactly which model it is - it's located in the left hand rear side compartment in the boot. But if you have RSE, don't think it's as easy to see or get at without removing the DVD changer and/or other pieces.
Post #473793 25th Mar 2018 10:48am
