![]() | Home > Technical (L322) > Tdv8 3.6 6 speed gearbox issue |
lazylabs Member Since: 01 Nov 2016 Location: Lincoln Posts: 78 ![]() ![]() ![]() |
Hi
Thanks for the reply..
unsolicited Member Since: 30 May 2016 Location: Bucks Posts: 130 ![]() ![]() ![]() |
Try first resetting ENGINE adaptations (NOT gearbox adaptations) with the IID tool. Let the car re-learn and see how it goes.
chefkenmore Member Since: 11 Jan 2015 Location: Fearnan perthshire Posts: 761 ![]() ![]() ![]() |
Watch the revs? 1800-2000
I'll give the engine adaptations a reset thanks.. How did yours come about?
Just exactly that, pulling uphill with the caravan on the back!
If I did an engine reset, would it forget the Alive remap?
Adaptations? I doubt very much that would affect a map. |
re: How did mine come about. The answer is I don't know, since it did it from when I bought the car at 9 years old. It was fine in manual mode but would try very harsh downchanges when approaching kickdown on the accelerator. Enough to make you wonder if the gearbox had lunched itself.
Mikey Member Since: 10 Jan 2008 Location: Dundee Posts: 1850 ![]() ![]() |
Incorrect gear ratio faults require further investigation than just a judder... |
Yeah, that fault is worrying. Mine never logged any faults whatsoever. Solenoids? |
Cam-Tech-Craig Member Since: 04 Aug 2011 Location: Gloucestershire Posts: 16392 ![]() ![]() ![]() |
I’de start with the software... Have you tried any kind of updates? |
Not tried any updates as yet..
@cam-tech-craig...
