Home > Technical (L322) > Diff oil choices
Rangie in oz
United Kingdom 2003 Range Rover Vogue Td6 Epsom Green
Diff oil choices
Hi, just wondered what the concensus was on using any 75w90 synthetic gear oil in the diffs as castrol saf xo is very hard to get here in oz.
also any ideas on an alternative to castrol botfmb1 in the transfer box?
any help would be great
cheers
neil 03 TD6 vogue....Epsom, very nice
03 TD6 se....gone Sad
94 Vogue se....gone Sad
Post #47213 24th Jan 2011 9:33am
tommac22
United Kingdom 2003 Range Rover Vogue 4.4 V8 Adriatic Blue
i have just (this weekend) changed all my dirveline oils, having looked around i opted to purchase from the deailer, with postage etc factored in there was very little proce difference. It may be worth ringing a uk dealer and asking them to post to you
Post #47214 24th Jan 2011 9:52am
Rangie in oz
thanks, will look into that. I get all my parts shipped from the uk as its still 500% cheaper than the dealers here.
thanks again
Post #47224 24th Jan 2011 10:29am
herman maire
Canada
Just buy any quality 75/90 . If you can get Red Line brand thats more than a great gear oil for our RR.
I had to buy some transfer case oil as the dealer is the only source for it, I asked them what brand they use for gear oil.
Answer, they just buy whatever castrol, penzoil ect... by the drum , nothing fancy.
Post #47352 24th Jan 2011 10:33pm
Rangie in oz
Thanks for that, I spoke to the dealer today, they had no diff oil in stock and told me the transfer is sealed for life ( we all know what that means ) and even the exchange transfers they fit come filled with oil??
spoke to castrol australia and they say that saf xo is made under licence to land rover and bmw and only delivered to them.
penrite is a good brand over here and they list a semi-synthetic 75w90 for the diff and a 75-80 for the transfer, I suppose a semi-synthetic will do as long as its all changed.
my rangey is at the age now where it needs good regular services and TLC so doing all the oils is no problem, been using penrite hpr 5-40 in the engine during summer and reckon its very good.
will check out the red line out.
cheers
Post #47374 25th Jan 2011 9:52am
tommac22
hi again,
as i said previously i purchsed the oil form my local dealer (matfords of exeter on 01392 823923) only a couple of weeks ago, it was off the shelf. I changed the diff and transfer box fluids at the weekend and the stuff that came out of the transfer box was horrid!
Give them a call and im sure they will be happy to help you. If i can be of any further assitance let me know.
Post #47378 25th Jan 2011 10:23am
Dolphinboy
Hi tom, have you noticed a marked change in your gearbox since? I am thinking about having my gearbox oil changed - coming up to 90,000 miles now. Still runs fine with no probs, but pre-emptive strike now may avoid later costly damage methinks.
Post #47379 25th Jan 2011 10:46am
Rangie in oz
Thanks tom, could you tell me what the uk price was so I can gauge the shipping?
thanks
Post #47380 25th Jan 2011 10:53am
we have an oil company as a sponsor, worth enquiring there?.
http://www.fullfatrr.com/forum/topic4359.html ... - .- -.
Post #47394 25th Jan 2011 12:04pm
adara
Romania 2019 Range Rover Vogue 2.0 PHEV Santorini Black
Is it safe to use compatible oils in the diff/transfer? If affirmative, what are the types and quantities?
Post #47403 25th Jan 2011 12:54pm
herman maire
Canada
For the differentials just use ANY good quality 75/90.
For the transfer case, ONLY use the correct oil specific to the transfer case, available only at the dealer.
Part#STC 4861 Its been a while but should still be the correct part #. It only takes 1 litre so not worth messing around with other stuff.
I just had my transfer case taking apart last week ( trying to track down a grinding noise) . There is synchromesh, clutches for the synchromesh and oil pump for the planetary gear set. For that reason the mechanic suggested only putting factory oil in it but mostly its because of the clutches for the synchromesh. You dont want a oil that that messes with the clutches.
I am sure you could find a transfer case that uses similar synchromesh/clutches and use that oil.... maybe the porsche cayenne .
Post #47409 25th Jan 2011 2:53pm
tommac22
Price wise. diff oil was £9.92 inc vat per litre and the transfer box oil was £9.20 inc vat per litre ( i bought 2 and used 1 and a bit to do a change) I do get some discount as my father in law is in the trade so may be slightly more!
Post #47418 25th Jan 2011 3:26pm
Rangie in oz
Thanks for the help guys, will use penrite in the diffs and get the transfer oil from the dealers.
thanks again for all the great advice.
Post #47547 26th Jan 2011 2:46am
tommac22
@ dolphinboy, yes it certainly seems smoother on th change, not sure the transefer box/diff oils made much differenc ebut the stuff that came out was not nice! cvar has covered 82k so plenty long enough on the oil in my opinion, when you consider on the 90's etc they get changed every 24k or so ( or yearly on mine) and they are far less complex.Well worth doing as preventitive maintenance.
Post #47551 26th Jan 2011 9:00am
adara
Just changed diff and transfer case oils, the front diff takes about 0.9 litres, the transfer box 1 litre (phew!) but the rear diff swallowed more than 1.4 litres, not just one as stated! The diff oils were ok, yellow and clean, but the transfer case oil was very dirty! The 75W90 diff oil is 7EUR/l, but the transfer one is 26EUR/l!
Post #48585 3rd Feb 2011 1:46pm
