![]() | Home > Technical (L322) > 4.4 fuel pump |
herman maire Member Since: 28 Nov 2010 Location: up north Posts: 51 ![]() ![]() |
I am quite sure they are not the same at all. The RR pump was built to run on steep grades, just do a search for the BMW pump then the RR and compare pictures. |
Yes they are the same - there is a caveat...
rathbranV8 Member Since: 23 Jan 2011 Location: meath Posts: 283 ![]() ![]() ![]() |
thanks for the speedy replys
Andy Member Since: 24 Feb 2009 Location: Shropshire Posts: 2947 ![]() ![]() ![]() |
I really need to get round to fixing my fuel sender as it doesn't read below 1/4 of a tank. I keep it half full all the time now, but there's always that chance of not finding a fuel station for miles.
The sender unit is part of the pump, I wonder if someone has removed the pump at some time and it needs calibrated again.
Does anyone know if it can it be reset? I'd rather have a heads-up on this, rather than dismantle the rear of the car, only to find its not the sender. 2010 MY Vogue SE TDV8 3.6 Stornoway Grey- fully loaded |
elpeede Member Since: 09 Mar 2010 Location: Staffordshire Posts: 713 ![]() ![]() ![]() |
Don't know about resetting. Just thinking of how they work.. it may be just a crap connection where the arm sweeps across the resistive wire which tells the level. Could be as simple as needing a bit of a retensioning Noddy. Only one way to find out I guess.. either that or run it in to be fettled.
