![]() | Home > General > Would I be crazy to buy a L322 with 100K+ miles? |
Grofus Member Since: 24 Mar 2017 Location: Co Clare Posts: 577 ![]() ![]() ![]() |
3k a year for maintainance seems high to me but then I'm handy with spanners. I have had an 07 TDV8 for 3 years and haven't spent that in total. Now on 106k miles.
Webbie Member Since: 02 Apr 2016 Location: Corby Posts: 137 ![]() ![]() ![]() |
3k was including parts labour at an independent and included tyres and brakes. Only the simplest of jobs done DIY. |
StClere Member Since: 26 Mar 2018 Location: Fife Posts: 5 ![]() ![]() |
I've not heard of the Iidtool, but I have a OBD2 scanner...are they basically the same thing? I was hoping that I could use my scanner on any RR that I went to look at. |
Tap Gap IID tool will do so much more than the basic code reading a scanner will do.
rar110 Member Since: 09 Aug 2014 Location: Brisbane, Australia Posts: 1119 ![]() ![]() ![]() |
Your OBD2 might allow you to read and clear codes which is good. In reality that’s what I do with my iidtool on most occasions. However I am a novice with it. I have used it to obtain live data such as trans temps, alternator outputs, EGTs etc. I’ve also used it to change settings, eg to change the alert tone for front parking sensors so that there is a different tone for the front and back. When parking in a tight situation I know whether it’s the front or back that is getting close. I’ve also used it to reprogram keys. The iPhone interface for the iidtool is excellent. It provides a lot of information eg multiple sensor read outs at the same time (see photo of screen I did for someone on here).
Yes, I've got the OBD2 to read and clear codes. It cost £15 and does the same job that most garages/dealers will try to charge you £100 a time!
Alistair Member Since: 11 Feb 2011 Location: Peterborough / Bordeaux / Andorra Posts: 8093 ![]() ![]() ![]() |
Read the Wiki - there's a buyers guide there - the Wiki is found at the top right of the page under where it says fullfatrr.com - it's kind of a greatest hits page of the best threads.
Mr101 Member Since: 02 Apr 2018 Location: Hawley Hants Posts: 26 ![]() ![]() ![]() |
I have just bought a 4.4 V8 Vogue with 258000 miles on it, in my defence it was very cheap but id did come with almost a full service history from the 2 previous owners. 4.4V8 L322 to keep me busy
