![]() | Home > General > I got stuck !!! |
| Gazellio @ Prestige Cars Member Since: 22 Jan 2010 Location: Chilterns, UK Posts: 11309
How did you get out? |
| David Member Since: 15 Oct 2010 Location: Murcia Posts: 301
F**KING about for ages, ended up droping the pressures right down in all the other tyres to lower the car at thouse corners giving the free wheel a bit more bite. 2007 TDV8 Vogue SE |
| dan_uk_1984 Member Since: 12 Nov 2008 Location: Bude, Cornwall Posts: 4014
Had you cross axled it? In theory with 4wheel ETC it shouldnt be possible. But maybe your brakes are poo. |
| Baben Member Since: 17 Oct 2010 Location: Kyalami Posts: 165
Wierd!
You want TC, otherwise your wheels will spin freely in mid air. It's DSC you want to turn off - because this cuts engine power.
Need a rear locking diff! |
Didnt switch off traction, but used all the other setings. Breaks are new dan ! Did my head in as the day befor i had it in sand mode and every thing worked well, i was going past others that were diging themselves out, including defenders, g wagons etc. What is cross axeling ? 2007 TDV8 Vogue SE |
i need to go sit in my car and look what the button says, but yes I think its DSC I am on about.
| Fox Member Since: 02 Apr 2010 Location: Essex Posts: 2313
You needed to switch of DSC and give it FULL THROTTLE !!! (even if for a short time)
Also Mud & Ruts setting encourages both wheels to spin (not slip) to remove mud from tyre treads..... |
ah, hang on, the locking rear isn't necessarily standard all over the world. It is here, thankfully. Didn't help when all 4 wheels are spinning in river sand tho |
I believe the Owners Manual describes various off road techniques - perhaps you should give it a read? I don't fully understand the benefit of a locking rear diff over traction control. Other than the fact that it seems antiquated tech, it just seems that it would create more problems than it would solve. TC will lock a spinning wheel that is hanging in the air (combination of heigh sensors and ABS sensors) and apply 100% of the power to the wheel with traction. A locking Diff allows no slippage between left and right sides - this means 50% of the power will go to each wheel... We already have auto locking centre diffs (have done since 1989) so front rear traction is always 50/50 split.
well not really, cos the diff doesn't just lock up, it gradually winds up the lock depending on the requirement
| Emperor Mong Member Since: 07 Jul 2010 Location: London Posts: 1435
Locking rear diff was only standard on the the 4.2 SC here in the UK, I believe. It was an option on all other UK models.
| All times are GMT |
