![]() | Home > Maintenance & Mods (L322) > TDV8 Rear Shocks |
| GraemeS Member Since: 06 Mar 2015 Location: Wagga area Posts: 2777
Does your vehicle have CVDs or standard shocks? CVDs are handed, standard are not. |
| Mr Tee Member Since: 13 Dec 2010 Location: Near Wackyjim Posts: 2724
Ah Active Dynamics? Had to do the mod on the front strut tops so yup, it's the dearer ones |
| Scottyav Member Since: 11 Feb 2013 Location: Cannock Staffordshire Posts: 1204
ive just replaced mine from britishparts they had a deal before |
That's basically why i'm getting confused, Dan quoted £309 each, so I'm worried that the £85 jobs won't fit. |
well they fit fine on mine give them a call they will tell you but yours id have thought were same as mine? and i have seen them more expensive on other sites |
Sounds like a plan, SWMBO almost wants a change of car into a newer one so any saving is a bonus cheers mate |
| CS Member Since: 14 Apr 2015 Location: Edinburgh Posts: 1431
Hmm, when my rear shocks (2012) started leaking I was quoted about £80, but was then told on here that that would be relevant only to earlier cars, you might want to double check that what worked on a 2007 car will work on a 2010. Only Range Rovers since 1988 |
Roger that |
Just by way of illustration, the Rimmer Bros website shows 'up to 2007' shocks at around the £80 mark depending on whether OEM etc and then later shocks at £270 or so. Only Range Rovers since 1988 |
upto yes but as mine are after and the later ones like the link his should be the same,i had that as well when i asked you can get early for £80 on some sites but there to 2006 in reality,these are NOT for the early models these are for the later models |
Mine is a 2010my 2009 registered, tft dash so , think best to call and check before wasting time & effort |
Call them they list your year in the add, i spoke to them on mine last month and they reiterated to me these were for the later l322, my 4x4 indy charged me £140 to fit the rear shocks and the four front suspension arms |
Ok mate I'll give them a bell in the morning |
CVDs were first introduced for MY10 and were standard on some configurations around the world but perhaps standard on UK models. CVDs were fitted to all MY11/12 vehicles.
| All times are GMT |
