![]() | Home > Maintenance & Mods (L322) > gearbox |
| Grofus Member Since: 24 Mar 2017 Location: Co Clare Posts: 577
Are you sure the right spec oil was used? Who did the service? 2007 Vogue TDV8 in Zermatt Silver with Charcoal |
| RRPhil Member Since: 22 Aug 2011 Location: Blackburn, Lancashire Posts: 1042
Maybe worth checking that the selector cable clamp bolt isn’t seized, through corrosion, in its hole in the lever
| lawsey Member Since: 28 Sep 2015 Location: newcastle upon tyne Posts: 65
well its got worse.. off to Austrin Gearbox Specialists today for diagnostics.. Any good rebuilders as memebers??
| m@ttsFF Member Since: 12 Dec 2017 Location: Surrey Posts: 338
^^ P525
well they have checked it over, lubed the trans cable, checked oil.and road tested. Not losing drive?? so hopefully fixed. other than that no fault codes so try it for a week see how it goes?? |
| roblane65 Member Since: 01 May 2017 Location: Newcastle Upon Tyne. Posts: 83
For what it's worth I've used austrin before and they really seem to know their stuff diagnosed the transfer box fault in mine when I'd previously been told by another so called idependent they 99.9 % certain the transmission noise was the front diff and quoted £2300 for the repair , I wonder what they would have done when I picked it up and it still had the same noise |
| All times are GMT |
