Home > Technical (L322) > new battery
BOBCUSSEN
France 2004 Range Rover Vogue Td6 Java Black
new battery
HI GUYS
ive just replaced my battery today: and what a Censored job it is to get the old one out !!!, perhaps im weak now but in the end i had o clime onto the engine and attempt to lift it with 2 hands completely square on, which it came up and out eventually just as i was about to give up: it looked like it would perhaps come out easier if the lip at the bottom, either end was cut off ?
i had asked my local garage in france to order the VARTA L1 020 110ah 920 a priced at around 150euro: but when i went to collect they had ordered a FIAMM L6 110Ah 920A which was 240 euro Censored ,and he pointed out that its a very good pne with 3 years warrrenty: which he thought was good; until i pointed out that the varta is i believe 5 years;
anyway i didnt argue as i needed to get back on the road;
i have two questions;
1, has anybody used these Fiamm bats before; and if so, are they a good brand
2, what would you expect to see the voltage reading to be when putting a metre across the poles, ie what would denote a poor condition battery ? below 12 ?
or is that not a sufficient test
just curious guys , thanking you in advance Bow down Bow down
Post #474288 29th Mar 2018 6:54pm
Did you put the bonnet into access mode sir? Makes life a lot easier Thumbs Up
Post #474307 30th Mar 2018 12:08am
BOBCUSSEN
HI
yes i Big Cry did; but even standiing on a crate; i found i couldn't get a straight lift on it as to the angle of approach; ( and a dodgy arm ), which didn't help, but each time i tried to lift it, it caught on the lip running around the bottom of the battery; but in the end i clambered up onto the engine cover and managed to get a straight lift on it which came out ok, but they have not allowed much leaway for a battery of 39cm !!
still its done now thank Censored Thumbs Up
Post #474323 30th Mar 2018 9:10am
Discotigger
I've just replaced my battery last weekend, swapped out the genuine varta LR battery (110ah 850cca) for the Varta I1 110ah 920cca s020. It was a straight swap, but I agree it's a fiddly job. The Varta I1 nly cost £123.50 for the battery and a FIAMM L6 is only 144 euros on ebay so I reckon you've been shafted by your supplier in having to pay more for something they've foisted on you. If I was you I'd certainly complain to the supplier and ask for some money back.
Post #474411 31st Mar 2018 12:20pm
Always worth spending a little time getting all the cables and piping out of the way as well, this makes the "out" and the "in" much easier
Thumbs Up .
Post #474419 31st Mar 2018 3:18pm
BOBCUSSEN
yes i was thinking the same thing; my supposedly friendly garage: 100e over the top, i will have words and get them to speak to the supplier
Post #474428 31st Mar 2018 4:30pm
BOBCUSSEN
yes i removed the earth lead completely as it was catching the corner of the battery: Thumbs Up
Post #474429 31st Mar 2018 4:32pm
