![]() | Home > Technical (L322) > Towing in Germany / Anhänger ziehen in DE: Question/Frage |
| FrankRizzo Member Since: 27 Aug 2012 Location: Frankfurt am Main Posts: 222
I'm new to towing and have a standard class B German license. I'm having trouble understanding exactly how heavy a load I'm allowed to tow with the L322. It seems the car and trailer including load are not allowed to exceed a combined weight of 3500kg with a class B license. This means I can only pull a 800kg trailer and load. Is this right? I've seen L322s towing much larger trailers on the roads in Germany. Have I misunderstood the law or should I assume they have a different class of license? Can I tow more if the trailer has its own brakes?
| lounge_on_wheels Member Since: 10 Dec 2016 Location: in the great land of oz Posts: 269
In Australia, Tow ball weight needs to be taken in consideration also . |
| Meerbusch Member Since: 16 May 2012 Location: Zürich (CH) + Düsseldorf (D) Posts: 327
The answer is here:
| IanV8 Member Since: 14 Jan 2010 Location: Dunfermline Posts: 502
The rules about weights are the plated weight so even if your RR is empty you cannot tow anything without a B+E.
Thanks for the feedback |
| All times are GMT |
