![]() | Home > Technical (L322) > 2010 5.0SC Gearbox/Transfer Box Failure |
| GGDR Member Since: 26 Nov 2016 Location: London Posts: 3561
I think the 5.0 has the same 8-speed gearbox as the 4.4 diesel. There are a few of us here including Baltic Blue who has complied a fault list and I can't say I've heard of this myself. The diesel has 700nm of torque which is more than the 5.0 I think. Some have chipped their diesels up to 800nm and trans failure has not been really mentioned a lot or at all. It's been discussed that 700nm is at the upper limits of this box though. Anyway if it was driving style, we'd have heard about it. Or lunched a few boxes ourselves.
cancel that, 5.0 has a different box.
| cass Member Since: 12 Oct 2011 Location: northumberland Posts: 797
I've seen a reply almost exactly the same wording that was sent about a different (known) problem on an out of warranty Rangerover. I think this is pretty much what any manufacturer would respond to an issue on an 8 year old car, I certainly wouldn't expect them to accept any responsibility. |
| RoverDramas Member Since: 04 Apr 2018 Location: Cambridgeshire Posts: 6
Hi
| bishbosh10 Member Since: 25 Apr 2013 Location: North Somerset Posts: 344
Perhaps, but after 8 years as said above, no manufacturer is going to give a monkey's unfortunately.
The age of the car is irrelevant to the question I posed. Chronological age is not what has caused this component failure. Neither did I request that they accept responsibility, I simply asked them to confirm whether they would expect a Land Rover Range Rover gearbox output shaft to have lasted just 61,000 miles. Given that they have suggested this, I have asked them to produce the documentation that describes the specific driving style that causes this premature failure and when this documentation was distributed to every Range Rover user on how they should and should not drive their cars. Last edited by RoverDramas on 4th Apr 2018 1:42pm. Edited 1 time in total |
It's already been done. The point of my question is because my warranty company are suggesting this is "wear and tear" which is remarkable on a part such as this. The gearbox shaft in question is not inspected at any regular service, it does not form part of any service schedule, it cannot be viewed or inspected without the removal of the gearbox or transfer box and were it the case that it might fail in less than 62,000 miles it really should be included somewhere. I wanted Land Rover's take on the suggestion that their gearbox output shafts are made of chocolate. |
| counter of beans Member Since: 18 Aug 2017 Location: Hampshire Posts: 182
I have no experience of JLR's attitude I'm afraid. But if your warranty provider is saying this failure is "wear and tear" I'd be amazed, and quite frankly rather angry! If a warranty doesn't cover something like this then what is the point of it?
| RRPhil Member Since: 22 Aug 2011 Location: Blackburn, Lancashire Posts: 1044
Is the failure through fretting corrosion of the spline, rather than a torsional failure?
Absolutely, yes.
| GraemeS Member Since: 06 Mar 2015 Location: Wagga area Posts: 2777
The splines would have to be lubricated at assembly otherwise this would be a common failure - your vehicle got missed. The D4 WSM specifications for the transfer case input shaft spline list the lubricant.
Well you’d think so wouldn’t you, but Land Rover sent me an email today with the following, when I suggested a lack of lubrication;
I suspect that the shaft is coated with a dry lubricant by the TC manufacturer allowing the g/box and transfer case to be assembled without mess and therefore no cleaning-up during assembly. It might be dry but a lubricant none the less. |
| All times are GMT |
