Home > Technical (L322) > Range rover sport tdv8 blown turbos.
Craigy198989
United Kingdom 2009 Range Rover HSE TDV8 Barolo Black
Hi everyone,
New here, and I'm in a bit of a pickle.. Well major pickle.
2009 range rover sport TDV8.
Driving along minding my own business, sudden loss of power, loud whine, turbo failure. That's fine, 90 odd thousand miles it was going to happen at some point.
Took it to a specialist. Diagnoses Near side turbo spat it's dummy out.
2 weeks later I got it booked in at a garage with a good rep and good reviews. Quoted me a fair sum and I thought great, get back on the road.
Had the car for 5 weeks, replaced the nakerd turbo, put it all back together again.
Went to test drive it straight into limp mode and an endless list of engine management faults.
Everything was saturated in oil, so started to clean and stripping each and every sensor, cleaned out exhaust, new gaskets and ended up replacing 2 maf sensors.
Put it all back together again and away we go.
I've been told he used a tenners worth of diesel driving it around make sure everything is as it should.
I pick the car up the day after, drive it 10 miles and boom! Loss of power, clouds of blue/white smoke. Get it towed straight back to the garage.
Stripped it all apart again, diagnosis, blown the other turbo and blown the new turbo.
So it's been stripped down again.. Turbos are being sent away for diagnosis. And I've been told a potential engine rebuild is likely..
I'm feeling stuck between a rock and a hard place.
What could cause a turbo to fail so quickly..
I did notice on my short 10 mile drive, when I initially turned the car on a puff of white/blue smoke from the exhausts.
It didn't feel as powerful as it did before the turbo went the first time.
I've been reading up about potential blocked dpf? Can cause instant turbo failure..?
Any advice or knowledge would be highly appreciated.
Thanks
C
Post #474920 5th Apr 2018 5:22pm
You probably want http://www.rrsport.co.uk
This forum is for proper Range Rovers Whistle
Post #474921 5th Apr 2018 5:29pm
CS
Sorry about your predicament. While the RRS forum may have more useful info, you could use the search facility on here, for example there is a thread headed something like "why TDV8 turbos fail" which might help. Only Range Rovers since 1988
Post #474936 5th Apr 2018 7:19pm
Seeing as we're being nice - here you go Very Happy
http://www.fullfatrr.com/forum/topic30634.html
Though failure does seem more common in the RRS.......
Post #474938 5th Apr 2018 7:40pm
Vogue
Blimey !!!!! Shocked Shocked feel really sorry for you.....
Probably not what you want to hear - but I know a farmer who has a cure for such an awful and expensive predicament =
SWAN VESTAS Thumbs Up 2021 L405 Vogue SE 4.4 V8 DIESEL ~ #17
Post #474945 5th Apr 2018 8:50pm
Laughing That does sound like the best solution Whistle
Post #474967 6th Apr 2018 7:45am
cheezels
Australia 2007 Range Rover Vogue TDV8 Java Black
Sorry to hear this mate.
Cause may possibly be oil starvation.
Check turbo oil outlet pipes for restrictions caused by oil sludge/carbonisation.
Oil transiting the turbo gets thermally stressed and can cause deposits restricting flow.
Let us know how you get on. 2007 3.6 TDV8
Post #475008 6th Apr 2018 2:14pm
rar110
I agree it does sounds like something going on around the turbos. It sounds like intercooler was laden with oil. ______________________________
Post #475174 7th Apr 2018 11:54pm
