Home > Technical (L322) > AC cold one side and hot the other
JohnnyDangerous
England 2002 Range Rover Vogue 4.4 V8 Java Black
Tried turning the ac on cold as its sunny today and the pass side goes cold from both dash vents but the drivers side vents keep blowing hot air! Is it as simple as the temp control switch on drivers side not working correctly? One day your life will flash before your eyes......................................make sure yours is worth watching!
Post #474929 5th Apr 2018 6:23pm
MikeO
Scotland 2009 Range Rover Vogue TDV8 Buckingham Blue
I think it's often the stepper motors that are controlled by the HVAC system. There is a reset routine on the Disco that is usually the first thing to try. Not sure if it's the same on the FF? Try a search on the Disco3 site for HVAC reset - might give you some clues to start. Or someone might be along soon with a better suggestion! 2016 Skoda Octavia VRS Estate
<gone>2009 FF Vogue TDV8 Buckingham Blue</gone>
<gone>2015 BMW 520D SE (not my favourite car)</gone>
<gone>2009 D3 HSE Galway Green</gone>
Post #474959 5th Apr 2018 11:07pm
JohnnyDangerous
Thanks I will have a look for reset procedure. One day your life will flash before your eyes......................................make sure yours is worth watching!
Post #474980 6th Apr 2018 9:42am
