![]() | Home > Technical (L322) > New MOT rules re DPF, should my aging TD6 be worried? |
wack61 Member Since: 17 Nov 2017 Location: Cheshire Posts: 104 ![]() ![]() |
Egr blank will if they check , TD6 hasn't got a dpf |
mjdronfield Member Since: 04 Nov 2011 Location: Derbyshire Posts: 7965 ![]() ![]() ![]() |
Don’t think they can strip anything, so if you take the egr off and replace with the blanking kit they won’t see it..... 2011 Range Rover Vogue SE 4.4 TDV8
zarnd Member Since: 22 May 2014 Location: Kent Posts: 459 ![]() ![]() ![]() |
No engine covers or undertrays are removed in an MOT. Your TD6 does not have a DPF either.
mrblonde Member Since: 24 Jan 2012 Location: Cambs Posts: 766 ![]() ![]() ![]() |
Thanks guys |
Just resurrecting this old posts guys, I read earlier about if any smoke it visable from the exhaust its a fail too on the new MOT, does this sound right?
As far as I know the visible smoke point only applies to vehicles fitted with DPFs
Mikey Member Since: 10 Jan 2008 Location: Dundee Posts: 1847 ![]() ![]() |
As above |
nearlee Member Since: 28 Feb 2018 Location: Where the sheep are scared Posts: 252 ![]() ![]() |
So when where dpf started appearing on ff's.
Spooky Member Since: 03 Aug 2009 Location: Swindon, Wilts Posts: 190 ![]() ![]() ![]() |
In the UK, it was with the introduction of the 4.4 TdV8; it was optional on the 2010 3.6 version, but not many took it up. Regards,
YEV1989 Member Since: 12 Nov 2018 Location: Yorkshire Posts: 1 ![]() ![]() ![]() |
My 2008 L322 3.6TDV8 has a DPF and I'm very much worried about the subjective visible smoke test. MOT due 22/12/2018.
