Home > Maintenance & Mods (L322) > Strut brake damper removal
cheezels
Australia 2007 Range Rover Vogue TDV8 Java Black
I’ve just changed out my front struts but can’t for the life of me get the ‘high performance brakes damper’ off the the top of the old struts.
It’s simply screwed on but the loctite is causing the whole assembly to turn so it won’t unscrew. I’ve cut the bags open to see if I can grip anything to stop the ‘cup’ from turning but couldn’t see anything obvious.
Anyone else had this issue. Any pointers appreciated.
Also, I’m not really sure what the dampers do, so if anyone can enlighten me that would be great.
And lastly, is it safe to drive without the dampers?
 2007 3.6 TDV8
Post #475070 7th Apr 2018 7:13am
fisha
I would be using a Stilson wrench to grip it. In general terms I’ve rarely failed with undoing things like that when using one. It will leave tooth marks but that’s acceptable sometimes. V8 or else ...
Post #475072 7th Apr 2018 9:02am
cheezels
Stilsons won't fit unfortunately
And my mole grips can't bite into it. 2007 3.6 TDV8
Post #475074 7th Apr 2018 9:16am
kezbo1981
United Kingdom 2006 Range Rover Vogue SE 4.2 SC V8 Buckingham Blue
I had exactly the same problem. As I was not going to use the strut anymore I cut into the metal (of the strut not the damper) just enough to crack the thread slightly, then it came off.
Post #475075 7th Apr 2018 9:19am
cheezels
Kezbo, that sounds like a plan.
Can you give me a bit more detail, please.
You mean you cut into the silver bit below the black bit? 2007 3.6 TDV8
Post #475077 7th Apr 2018 9:42am
kezbo1981
That's right. I did it sort of diagonally with an angle grinder. You need to do it carefully as you could damage the treads on the actual damper. You just need to cut it just enough so it will crack, a blow from a coal chisel usually helps once you have made a reasonable cut.
Post #475078 7th Apr 2018 9:50am
cheezels
Maaaaate, I'll give that a go.
Any idea what's it for and will the sky fall in if I drive without them.
Googleski calls them an 'insulator' 2007 3.6 TDV8
Post #475079 7th Apr 2018 9:59am
kezbo1981
Think they stop some vibration or resinence, but not 100% sure. I drove for about a week without them and didn't notice a difference, i dont think early models have them. But on your head be it!
Post #475081 7th Apr 2018 10:16am
cheezels
Ok thanks kesbo.
I’ll try the grinder route and see how I go 2007 3.6 TDV8
Post #475083 7th Apr 2018 10:43am
