Home > In Car Electronics (L322) > Ebay tracker
Balloonengineer
Ebay tracker
Has anybody got any recommendations or reviews on any of the portable ebay vehicle trackers available?
Best wishes
Glen
Post #475085 7th Apr 2018 10:54am
Flashman
England 2011 Range Rover Autobiography TDV8 Santorini Black
I was looking into GPS trackers and a few recommended a TK102 system. Seems to be around £10-£20 and you can wire it into the 12v supply. You call it (thanks Baltic Very Happy ) for location and some versions of it have a movement sensor. If you link it to livegps.co.uk you can track it live on google maps.
Not bought one yet, but thinking about it as a back up for a classic car project I'm working on. Tom
Current Drive
2011 4.4 TDV8 Autobiography - Santorini Black - Ivory Leather
Previous Drives
2004 Model Vogue Td6 (Touchscreen) - Java Black - Parchment Leather
1994 RR Classic 3.9 V8 Soft dash - Niagara Grey - Grey Leather
1972 Series III SWB Safari - Green (Hand Painted) - Black Plastic
Post #475089 7th Apr 2018 11:05am
Baltic Blue
I fitted one on my Td6 and then moved it across to my 4.4tdv8 .
It was very simple to install and works well.
One point, they need a second generation SIM card which are getting rare.
I tried fitting a 3G SIM card PAYG from o2 which was supposed to be backward compliant to 2g but I couldn’t get it to work so ended up with a Libra PAYG 2g card. You have to make sure you use it regularly (say once a month) because they have a habit of deleting cards that are not used frequently even though they have still got plenty of credit left on them.
You ring the number, not text it, and it messages you back.
Post #475092 7th Apr 2018 11:32am
Zebedee
United Kingdom 2013 Range Rover Vogue SDV8 Santorini Black
I use this type and it works very well...
https://www.ebay.co.uk/itm/Car-Vehicle-Glo...1438.l2649
I tried a cheaper one, and that wasn't accurate so gave up with that one. The manuals are not great, but OK if you work out what they were meaning to say. You either text or call the number and it texts back with a Google maps link of where the car is, or you can use a website for live tracking.
I use mine with a Gifgaff PAYG sim topped up to about £10, which doesn't seem to need to be used with any particular frequency. There is an automatic top-up function too so can just forget about it. Current:
- 2017 L405 3.0 V6 Autobiography
Sold:
- 2013 L405 4.4 TDV8 Vogue
- 2004 L322 4.4 Vogue (BRC LPG)
- 2002 L322 4.4 HSE (having fixed timing chain guides)
- 2000 P38 4.6 Vogue (BRC LPG)
- 1981 2-door In-Vogue
- 1980 Ex-Army SIII LWB
- 1976 SIII LWB
- 1968 SIIA
Stripped for parts:
- 2003 L322 4.4 Vogue
Post #475095 7th Apr 2018 11:44am
smudge68
United Kingdom 2012 Range Rover Vogue TDV8 Zambezi Silver
I use one of these, hidden in the dashboard and wired to a ignition 12v feed so it bursts into life when the car is started without draining the battery when the car is left standing for long periods. A PAYG sim card (a £10 top up lasts for about a year dependant on usage) and a lifetime subscription to GPS Live. I get a notification on my phone if the vehicle moves and the tracking seems spot on with mobile phone and desktop apps giving accurate location details.
https://www.rewiresecurity.co.uk/102-nano-...-wired-kit
Post #475147 7th Apr 2018 5:58pm
p38arover
Australia
I had a TK102 device which I carried in my pocket when motorcycling** but stopped using it when the 2G network closed. It worked well. I had a cheap 365 day expiry SIM in it. One disadvantage was network coverage in some areas where I rode.
I need to source a 3G tracker. The TK102 wasn't even though the advert claimed it was.
** Why when riding? 10 years ago my son disappeared from a motorbike ride (he was Tail End Charlie). The other riders searched for hours. He was found some 5 hours later by a passing ambulance that saw tracks leading into the bush. He was dead. Ron B. VK2OTC
2003 L322 V8 Auto
2007 Yamaha XJR1300
Post #475176 8th Apr 2018 12:09am
That sent a shiver down my spine - and I guess explains your emoji Sad
Post #475184 8th Apr 2018 8:33am
p38arover
Australia
It does. His username on multiple fora was Bucko.
I ride his last bike purchase (Yamaha XJR1300) and wear his Marlboro jacket. Ron B. VK2OTC
2003 L322 V8 Auto
2007 Yamaha XJR1300
Post #475189 8th Apr 2018 9:17am
