Home > In Car Electronics (L322) > Reversing camera
Grofus
Ireland 2007 Range Rover Vogue TDV8 Zermatt Silver
Reversing camera
I upgraded my camera yesterday and it works well with a very clear picture both day and night.
Only I didn't realise the camera has a permanent live while the ignition is on. I need to swap it for a live from the reversing lights as the camera has LEDs around it which are now on when the ignition is on.
(Sure to interest the police if left on whilst driving)
Anyone know a good place to pick up the feed from and to the camera. Chasing wires isn't a strong point of mine so any advice welcome
Edit; Oops, thought I'd posted in Maintenance and Mods Embarassed 2007 Vogue TDV8 in Zermatt Silver with Charcoal
Post #475356 10th Apr 2018 9:36am
Jamiehol
United Kingdom 2007 Range Rover Vogue TDV8 Stornoway Grey
When I fitted one to an earlier L332 I picked a reversing light feed up from the when they pass through the grommet to the lower tailgate from the boot.
Do you have a link to the camera as I need a new one.
Post #475373 10th Apr 2018 5:16pm
roblane65
X2 for camera Wink Range rover 4.2 SC 06MY.
Post #475374 10th Apr 2018 5:26pm
Grofus
I got the camera off aliexpress. I wouldn't use the same one again because the LEDs cause issues.
1) I can't use the clear plastic cover from the original housing as the LEDs produce a glare on the screen
2) The need to find a live feed from the reversing lights
3) As a result of feeding the live from the reversing lights I'm getting a blank screen with the engine running. I think it's the LED bulbs I upgraded to causing the interference. I'm hoping some ferrite beads or other type of choke will sort it.
I will put the standard bulbs in tomorrow to check its them causing the problem.
Strange though how its only with the engine running. Banging Head
If anyone has any thoughts please pass them on 2007 Vogue TDV8 in Zermatt Silver with Charcoal
Post #475430 10th Apr 2018 11:16pm
Andy K
United Kingdom 2005 Range Rover HSE Supercharged Rimini Red
Put some black tape over the leds !
Post #475433 11th Apr 2018 12:07am
Grofus
That's an option I've considered if I can't sort it. Paint though, tape would be fiddly Thumbs Up ? 2007 Vogue TDV8 in Zermatt Silver with Charcoal
Post #475434 11th Apr 2018 12:20am
Grofus
Same result with standard reversing bulbs so interference is from elsewhere. As its only when engine is running I'm guessing it's the alternator. Neutral 2007 Vogue TDV8 in Zermatt Silver with Charcoal
Post #475457 11th Apr 2018 12:06pm
Grofus
Tried some ferrite beads on the live feed but no difference so wired back to the original live and put black silcone over the leds around the camera.
Fitted the original plastic lens back on and every thing is working and crystal clear Thumbs Up 2007 Vogue TDV8 in Zermatt Silver with Charcoal
Post #475526 11th Apr 2018 9:31pm
