Home > Technical (L322) > Head Gasket Replacement - cost and recommendations?
Sennokian
United Kingdom 2003 Range Rover Vogue SE 4.4 V8 Epsom Green
After investigating a problem with failed belts, I discovered the water pump had failed. You could move the fan significantly.
While replacing the water pump, I discovered that the two ali pipes that return coolant from the manifold at the back of the engine had come free and the coolant was just lost immediately... this was fixed in a garage, but after the job was complete, the engine has now failed a pressure test. We also did a coolant test (looking for contamination) and itโ€™s pretty clear there is a failure in the head gasket. The coolant boils a few minutes after the engine is started.
So, it looks like a new head gasket, which will also require a head skim, and I think there is another gasket that should also be replaced - weโ€™ll thats what my mechanic says anyway.
Does anyone know the likely cost of this work, and have recommendations of anyone south of London or Kent that is reliable?
Also, anything else I should maintain while the top is off, or any notes on the head gasket changing procedure to make sure I get the best job done?
F***.
Post #475372 10th Apr 2018 4:51pm
Dolphinboy
get your chain guides done. They become brittle after 100,000 miles or so and then shatter. also look at your oil cooler and radiator of damage adn sludge in bottom. change them if they are original.
Post #475377 10th Apr 2018 5:46pm
Sennokian
Thanks.
Good call on the chain guides. The oil cooler is on the list. Iโ€™ll have a look at the rad.
Post #475422 10th Apr 2018 10:17pm
Dolphinboy
Forgot to applaud you on your great choice of car by the way! ๐Ÿ‘ป๐Ÿ‘๐Ÿ˜Ž๐Ÿคธโ€โ™€๏ธ๐Ÿ‘๐Ÿ›ฐ๐ŸŽฏ
Post #475425 10th Apr 2018 10:44pm
holidaychicken
These lads are really good
http://www.ahlengineering.co.uk/
Post #475431 10th Apr 2018 11:34pm
Dolphinboy
@OP,
what was the result of this? Any joy?
Post #513173 25th Apr 2019 6:14pm
Essex1959
United Kingdom 2004 Range Rover Vogue 4.4 V8 Giverny Green
Re: Head Gasket Replacement - cost and recommendations?
F***.[/quote]
Have a look at Rave the information is comprehensive and illustrates a step by step guide on HG replacement procedure
Post #513243 26th Apr 2019 8:51am
Gsxr1250dave
Op total 4 posts 2 years ago dont think your ever gonna find out what his final out come was
Post #513271 26th Apr 2019 1:06pm
Gsxr1250dave
He are a couple of pics of my mates rebuild
Post #513272 26th Apr 2019 1:08pm
ohuntsman
United Kingdom 2002 Range Rover Vogue 4.4 V8 Zambezi Silver
Ring Engineering did our head gaskets 50k miles ago and it has been fine
https://www.ring-engineering.co.uk/
Post #513762 30th Apr 2019 8:15pm
Dolphinboy
@ohuntsman and GSXR dave,
How much did it cost please?
Post #523799 5th Aug 2019 11:34am
ohuntsman
Sorry Iโ€™ve just seen this.
It was about ยฃ2,500
Post #524602 13th Aug 2019 12:22pm
Gsxr1250dave
The complete engine rebuild wasnt even 2500 and we fitted a replacment bottom end !
I can ask my mate how much todo your head gaskets but its all dependant on your location
Post #524658 13th Aug 2019 5:37pm
