Home > Maintenance & Mods (L322) > GM 5 speed auto
A.Pires
Portugal 2002 Range Rover Vogue Td6 Zambezi Silver
GM 5 speed auto
Probably this has already been discussed here but I can´t find where.
Next oil change in my gearbox GM 5, I plan to replace the oil by the Dexron VI
What are the pros and cons to replace the Dexron III for the Dexron VI?
Cheers
Post #475568 12th Apr 2018 10:28am
RRPhil
Dexron VI supersedes Dexron III i.e. it’s backwards compatible.
On paper Dexron VI has a lower viscosity, which could be significant if your valve block assembly is worn and therefore leakage could increase. In reality though, Dexron VI is more resilient/stable and its viscosity will not reduce over time as much as Dexron III did.
Phil
Post #475586 12th Apr 2018 1:58pm
A.Pires
GM 5 speed auto
So Phil,
Your advice is that I can use Dexrom VI instead of Dexron III.
I Own the RR TD6 for about one year. I've change the oil on the gearbox and I intend to replace it when it makes 25.000 Kms +-.
I intend also to add a bottle of Lucas transmision fix just to prevention,
Am I correct?
Thank you and best regards
Post #475644 12th Apr 2018 9:20pm
