Home > Technical (L322) > 2006 4.2 supercharged engine removal
BigBadBob
United Kingdom 2006 Range Rover Supercharged 4.2 SC V8 Barolo Black
A manifold bolt sheared and the exhaust is blowing, i cannot get at it to repair it so it seems the engine has to come out. Can the engine be removed without removing the subframe (this is the model with subframes not a chassis.)
Post #475691 13th Apr 2018 12:52pm
Unless it is different for the SC, RAVE is showing a fairly straightforward procedure to access and remove the manifolds. Surely it is worth a try, going to be much easier than taking the engine out! .
Post #475696 13th Apr 2018 1:48pm
theres a 2006-2009 WM in the wiki that could help.. ... - .- -.
Post #475697 13th Apr 2018 1:50pm
BigBadBob
The bolt has sheared off and it needs drilling out so it would be impossible to get a drill in
Post #475705 13th Apr 2018 2:39pm
m@ttsFF
United Kingdom 2006 Range Rover Supercharged 4.2 SC V8 Buckingham Blue
Just had similar on one of my bikes ... i got a nut and welded it to the sheared stud , so if you can get a mig torch in there I’d give it a go before pulling the lump 4.2 SC - sold , now bought back
4.4 AdBlu Tractor - Stolen
Post #475708 13th Apr 2018 3:02pm
SoggyBottoms
United Kingdom 2007 Range Rover Vogue Supercharged Zambezi Silver
weld a stud onto the sheared bit? lol ^^^^ we had the same idea
Post #475709 13th Apr 2018 3:04pm
Strider
England 2007 Range Rover Vogue SE 4.2 SC V8 Zermatt Silver
What about a right angled drill adapter ??
https://www.machinemart.co.uk/p/rad-1-righ...ttachment/
https://www.amazon.co.uk/Right-Angle-Keyle...B000NBYFU2
If you decide to go down the "weld a bit on the end route" please remember to disconnect your battery,
90 amp + will give all the ecu's a real bad day.
Post #475764 13th Apr 2018 7:44pm
https://www.ebay.co.uk/sch/sis.html?_nkw=A...2749.l2658 .
Post #475774 13th Apr 2018 9:03pm
