Home > Technical (L322) > Annoying squeak /squeal
Dave
Was driving home the other day, I was driving for about an hour so the car was warm. I heard a intermittent squeal, though I thought the squeak was from the car in front, until it turned off, then I opened my window and discovered it was me.
Initially I thought it was from the front drivers wheel, but could see nothing wrong. I then drove to my local garage who took it for a test drive, he wasn’t sure what wheel so he got out while I drove, the squeal was very apparently coming from the rear drivers side. When the car is driving in a straight line there is no squeal, but if I apply even the slighted turn to the right the squeal returns. He checked the wheel bearings and said there was a little play but nothing mayor. The rear brake discs were good, and no scoring on the disc to suggest a trapped stone. I haven’t checked the hand brake shoes. When I first drive the car from cold, theirs no squeal, it only starts once I've done about 5 miles ish, when everything is warmed up
Anyone had a similar situation, or any advice please? Dave
2012 Vogue Westminster 4.4
Post #475648 12th Apr 2018 11:17pm
millerj90
United Kingdom 2016 Range Rover Autobiography SDV8 Loire Blue
Sounds very much like what I had. Turned out to be a seized caliper.
Post #475650 13th Apr 2018 12:10am
Dave
Thanks mate, did you just clean the caliper or replace it? Dave
Post #475651 13th Apr 2018 12:12am
Webbie
I had a similar problem, but didn’t resolve it in time and ended up with a warped disk. My sticking pads were due to the corrosion on the calliper carrier. Remove the carrier file back the area where the the pads rest on the calliper carrier to remove all of the rust and use CeraTec on those surfaces. Don’t be shy in filing back to remove all the rust, I ended up having to strip down a second time.
There is a good chance the callipers are ok. The calliper sticking is more common on the earlier type of breaks, rather than the Bembo set up on the 4.4TDV8.
Post #475659 13th Apr 2018 8:25am
millerj90
Dave
I had the caliper replaced. My independent, who I trust, said it was too far gone to repair.
Some people have managed to rejuvenate them though.
Post #475663 13th Apr 2018 9:26am
Webbie
I ended up replacing, disk, pads and calipers. Hope yours is an cheaper fix.
Post #475679 13th Apr 2018 11:31am
Dave
Thanks for the replies guys. As it's only just started and I've only driven the car for a few miles since, i'm hoping i can resolve it with too much expense. Dave
Post #475800 14th Apr 2018 2:42am
dolph34
Ireland 2015 Range Rover Autobiography SDV8 Corris Grey
The rear calipers aren't expensive , too think i paid 50ish for one on my 3.6. 2015 4.4 AB
GSXR 1000 K5
R1 1998
Post #475806 14th Apr 2018 9:39am
Webbie
Sadly the larger Bembo set up on the 4.4TDV8 means the exchange rear calliper are around £170 each Big Cry
Post #475809 14th Apr 2018 10:31am
Dave
D'oh, cheers for the bad news lol Dave
Post #475868 15th Apr 2018 2:05am
