Home > Technical (L322) > Suspension Fault and Dynamic fault
L19 MUD
United Kingdom 2009 Range Rover Vogue SE TDV8 Stornoway Grey
Hi All,
2010 MY car
I have got a clonk on my front right suspension which I cannot find and may not be related to this but thought I would mention.
In the last few days I have had suspension fault ping up and then the last two days Adaptive dynamic fault too. If I go into the 4x4 screen I can see that the front right wheel is showing as lower than the other three and there is a little red light flashing under this wheel.
The most obvious thing I thought of was the height sensor bracket has snapped but this looks fine. It is being plugged in on Thursday but wondered if anyone had had a similar problem?
I have checked the wires into the top of the strut as per a Wiki post on here but they seem fine - at least at the top as I have not traced further down
Post #476123 18th Apr 2018 9:01am
Baltic Blue
Mine has broken 3 times in total, twice on the passenger side and once on the drivers side.
Each time the break has been very close to the exit of the rubber grommet.
If you check the Fault codes on an iid it will tell you which side has failed.
 G reg 2.5VM Vogue Portofino red 1991- 1999
Post #476126 18th Apr 2018 10:07am
nino_nino
replaced mine two day ago with pure copper silicone wire. it should last a long time. got it from the hobby shop.
Nino,
Post #476138 18th Apr 2018 2:56pm
Baltic Blue
I am working up to doing mine this weekend, but I have found some black plastic tubing to sleeve it.
Post #476153 18th Apr 2018 5:10pm
L19 MUD
As per usual I am not so lucky... No broken wires I can see at the top. Before I start chasing around in vain I will get it plugged in
Post #476156 18th Apr 2018 6:18pm
Baltic Blue
Nino,
I have just had the top off the strut again and removed the plug.
The pins are tiny.
Did you join into the existing wires near the plug or did you find a way of connecting the new wire directly to the plug ?
I think the new silicon covered wire I have bought is too thick. I think I bought 16swg.
Can you say what size you used?
Cheers
Post #476230 19th Apr 2018 3:14pm
nino_nino
Mike, I could not figure out how to take pins from the plug, and not having spare one (minimum 2 weeks for delivery)
didn't want to take any chances. i cut wires approximately 1 1/2 cm from the top of the plug and solder new wires with shrink tubing over. i don't know swg of mine wire, it is slightly smaller than original, but with more and finer strands. 16 swg is fine as long as it will fit thru the rubber grumet. Thumbs Up
Nino,
Post #476238 19th Apr 2018 5:12pm
Baltic Blue
Thanks Nino,
I also can’t see how to solder directly on to the pins so will do exactly as you have done.
Once again you lead the way 🍷🍷
Cheers
Post #476249 19th Apr 2018 6:07pm
funnyguy1
United States
I soldered mine the 1st time and then replaced them with the factory repair kit which just took a few minutes. There are pics of the kit somewhere in this site.
Post #476423 21st Apr 2018 5:23pm
