![]() | Home > Technical (L322) > 3.6 TDV8 Map |
dolph34 Member Since: 14 Sep 2015 Location: Kildare Posts: 1724 ![]() ![]() ![]() |
My 3.6 was remapped and it flew. Felt much more responsive than my 4.4. ( haven't got around to remapping yet)
Alistair Member Since: 11 Feb 2011 Location: Peterborough / Bordeaux / Andorra Posts: 8065 ![]() ![]() ![]() |
Lots of people mapped their 3.6’s with no problems - I sold mine at about 130k miles
Grofus Member Since: 24 Mar 2017 Location: Co Clare Posts: 577 ![]() ![]() ![]() |
ZF 6 speed box is good for 740 NM of torque. 3.6 Fatty produces 640Nm torque as standard.
nearlee Member Since: 28 Feb 2018 Location: Where the sheep are scared Posts: 252 ![]() ![]() |
Slightly off topic...
lewis93 Member Since: 23 May 2017 Location: kent Posts: 28 ![]() ![]() ![]() |
Yeah been thinking of doing the BAS re-map which can be done at home via pc, this can also be turned on and off from home so its a high possibility for me.
Hi Grofus, i was under the impression that 3.6 tdv8s had the zf 6hp which is rated up to 640mn. 2015 4.4 AB
ZF website says 6hp26 is rated to 600Nm. 6hp32 rated to 750Nm. Can't see JLR would fit an engine capable of 640 NM to a box capable of 600Nm. I'm sure I read that Fatty 6 speed was up to 740Nm so assumed it was uprated to 6hp32.
stan Site Moderator Member Since: 13 Jul 2010 Location: a moderate moderated moderator moderating moderately in moderation Posts: 35771 ![]() ![]() |
hopefully this will clarify things,
Thanks Stan,
640Nm is the engines max torque. The table doesn't show what gearbox will take so it's still a mystery!
WCA Member Since: 15 Jan 2017 Location: Hampshire Posts: 26 ![]() |
Not exactly what you asked but I am sending back my Torqueing Diesel booster book. My review is on the other forum
