![]() | Home > Maintenance & Mods (L322) > Bleeding Jack |
supershuttle Member Since: 20 Mar 2011 Location: Lancashire Posts: 3927 ![]() ![]() ![]() |
I have a Merc Sprinter Jack but its running out of puff before it gets to a sufficient height to remove wheels - it was OK. I've ordered some Hydraulic Jack Oil to bleed it and the top it up but I just realised I don't know how to do it - can anyone help? Geoff |
Giantlandyman Member Since: 25 Nov 2015 Location: Essex Posts: 800 ![]() ![]() ![]() |
There's several clips on YouTube for bottle jacks in general. I don't know if any of them will be relevant. |
Cheers mate, I had a look you are right. If it confirms to "the norm" I should be OK, I've ordered the Hydraulic Oil so will give it a try next week. Geoff |
Baltic Blue Member Since: 13 Aug 2015 Location: North Wales Posts: 3853 ![]() ![]() ![]() |
Broke it ?.
Alistair Member Since: 11 Feb 2011 Location: Peterborough / Bordeaux / Andorra Posts: 8064 ![]() ![]() ![]() |
I broke mine too |
northernmonkeyjones Member Since: 24 Mar 2012 Location: derby Posts: 8760 ![]() ![]() ![]() |
I removed the top cradle to fit a jacking adaptor and accidentally pushed the piston back too far, after that I couldn’t get it back together satisfactorily so it wen tin the bin...... new one on its way from the bay. There is nothing that can't be fixed with a hammer😜😜
New jack has arrived. all shiny and new.
Vogue Member Since: 31 Jan 2008 Location: on the hill Posts: 3805 ![]() ![]() |
Why on earth are you jacking up a twin axle trailer ???? Far far simpler, quicker and safer You can even make one out of a block of wood or just drive up a car ramp or even a kerb ![]() |
Now that is a good idea!! There is nothing that can't be fixed with a hammer😜😜
Easy job but it still leaks fluid, I needed the jack to rotate the tyres because the front nearside had taken a bit of a hammering - roundabouts I think, job now done. However I still have the issue of tyre pressures I’ve got 22” wheels on an L322 I went with 33 front and 36 rear as suggested for L405, seems OK anyone have a different setup.? Geoff |
stan Site Moderator Member Since: 13 Jul 2010 Location: a moderate moderated moderator moderating moderately in moderation Posts: 35770 ![]() ![]() |
use the spare when rotating the wheels.. ... - .- -.
I've only got 4, spare doesn't match |
I saw one of those, but seemed quite expensive and bulky for something I thought I didn't really need ![]() Whenever my trailer isn't in use, I jack it up and replace all 4 wheels with stands - so I'm kind of programmed to just jack it up. Mine still has the 'ears' on it, so relatively safe to jack a trailer axle as long as you don't drive off with it jacked up ![]() |
spare doesnt have to match Geoff...
