Home > Wheels & Tyres > Uneven tyre wear and rotating tyres
JamesD
United Kingdom 2016 Range Rover Vogue TDV6 Corris Grey
Well my car has just hit 30k miles and the front are down to 2.5mm and the rears are 4mm. On previous 4x4 I have always rotated the tyres to get even wear, but the advice when I bought it was not to do it on the L405. Now I need to replace all 4 as it's not a good idea to replace just the fronts on a 4x4....next time I am going to rotate between axles every 6k miles (at oil change) and should get 40k miles out of them Smile
Anyone else able to get more than 30k miles out of a set? 2021 L405 Vogue D300
2016 L405 Vogue 3.0TDV6 (Sold)
Post #476557 23rd Apr 2018 5:30pm
CS
The LR handbook does say not to rotate. Perhaps that is due to TPMS having to be reprogrammed, as it works on the basis of specific wheels in specific positions on the car. Only Range Rovers since 1988
Post #476558 23rd Apr 2018 5:38pm
2 tyres = £500
1.4mm difference = maybe 20-20% of that - so £100 to £125 ?
Every 30,000 miles, so say 2 years
So its a 1/2 cup of coffee per week order of magnitude problem Whistle
Post #476560 23rd Apr 2018 5:49pm
Rob99
Don't know about front to back but the LR service sheet for my Westie says that wheels should be swapped side to side at every service. 2021 D350 Fifty Edition - Carpathian Grey
2017 4.4 SDV8 Autobiography (2021-2024) - Santorini Black
2012 4.4 TDV8 Westminster (2016-2021) - Santorini Black
Post #476615 23rd Apr 2018 11:31pm
finchi
United Kingdom 2017 Range Rover Autobiography 5.0 SC V8 Carpathian Grey
Re side to side swap - wouldn't work if tyres are directional
Re TPMS - wheels/ TPMS valves can be moved to different locations, corners or spare wheel well, on vehicle without any issues from my experience.
Post #476623 24th Apr 2018 8:31am
JamesD
Yep I have had differing advice in the past, for my RRS I was told to do an axle rotation every 6k...it worked well and my tyres wore even. 2021 L405 Vogue D300
Post #476624 24th Apr 2018 8:52am
JamesD
Alistair wrote:
2 tyres = £500
Changing tyres when they still have 4mm of tread left just seems wasteful, it's not the money per say...just because you can afford it does not mean you can't be economical Confused 2021 L405 Vogue D300
Post #476625 24th Apr 2018 8:55am
