![]() | Home > Technical (L322) > Webasto (Telestart) T91 with T91R remote compatibility |
try a new battery in the remote ... ... - .- -.
Webbie Member Since: 02 Apr 2016 Location: Corby Posts: 137 ![]() ![]() ![]() |
Had the same issue, new battery worked for me |
Blencoe Member Since: 13 Apr 2018 Location: Gloucestershire Posts: 16 ![]() ![]() ![]() |
New battery fitted, still does the same multiple flashes of the light when trying to sync |
nicksaab Member Since: 28 May 2013 Location: Wimbledon and West Wales Posts: 560 ![]() ![]() |
Yeah I had that when programming mine recently. I'm sure I was doing something wrong when it came to programming it - I think I had I misread the instructions as holding the off button for 3 seconds rather than just pressing off within 3 seconds. I tried for ages one afternoon and had no success. Came out the next day and it did it first time, so I must have been doing something wrong, but I'm sure you aren't. Strange as I like to think I'm a reasonably bright guy but following 3 very basic instructions was clearly too difficult.
or try and leave the process for a while to let the ecu's settle down..
Thank you Stan for that vote of confidence! |
chris_read Member Since: 26 Feb 2012 Location: Louth, Lincolnshire Posts: 476 ![]() ![]() ![]() |
Please someone correct if they have personal experience to the contrary, but I was under the impression that the T91r only works with the L405 and that you need the T91 remote for the L322.
Chris_read my thoughts exactly.
Tinman Member Since: 22 Mar 2017 Location: kent Posts: 1210 ![]() ![]() ![]() |
Well guys after trying to sync my remote purchased from fleabay and reading Blencoe post, my T91 Telestart is not compatible
drakes Member Since: 26 Jan 2009 Location: Consett Posts: 373 ![]() ![]() ![]() |
Just a note for anyone looking for a reciever unit the T91R cannot be used on the L322 as it does not have an anologue output however the T90 and T91 are interchangeable as are the T90 and T91 remotes, I one of each both remote and reciever and all work fine. 2010 3.6TDV8 Stornoway Grey/ Black interior - gone
GraemeJudge Member Since: 10 Feb 2018 Location: Fareham Posts: 54 ![]() ![]() |
so what remote will I need for a 2004 td6 heater please |
dmhort120374 Member Since: 01 Nov 2018 Location: Rotherham Posts: 5 ![]() ![]() ![]() |
I have had the same issue, picked up a new T91 from Duckworth Dan £110 inc and problem solved.
aljo Member Since: 04 Jul 2018 Location: west sussex Posts: 202 ![]() ![]() ![]() |
would the T91R reciever fit a 2016 L405 Last night I lay in bed looking up at the stars in the sky and I thought to myself, where,s the f**king ceiling!!
Hi, Drakes PM sent |
