Home > Technical (L322) > Battery Dying?
paul70
Battery Dying?
I was previously concerned at getting low battery start engine warnings but after advice on here disabled the interior lights by pressing the centre button on the roof light and the problem has gone away when I had been leaving doors open for loading etc.
Last night went to go to work and pressed the start button and just heard a loud click and it didn't start.
Repeated and on 4th attempt it started and the starter turned over brightly.
Drove 5 miles to work and and this morning thought it was not going to start again. 3 clicks then started on 4th attempt.
I am guessing the battery is dying but i' am not getting a low battery warning on the dash now!
Should I just get the battery replaced anyway (Halfords do one fitted for £209) or is it more likely to be the started etc or do I need to replace the battery to just to discount that is the problem?
Unfortunately can't test voltages at the moment as my multitester is at the boat. But it doesn't look like Halfords stock the battery so I'll have to order one for tomorrow before I get chance to get my tester! I'm guessing the alternator is fine as when I've driven home and tried it started straight away, but if its a starter problem I guess it may be disguised with a hot engine?
Might just have to drive out later when I get out of bed. It was my last night shift last night so don't want to stop in bed too long anyway!
Regards
Paul.
Post #476784 26th Apr 2018 8:42am
i had this problem with mine, mainly after rain or a damp day..a new starter motor fitted and all is well.... ... - .- -.
Post #476785 26th Apr 2018 8:44am
CS
As Stan, everything powering up plus click when pressing starter, after several attempts it starts fine, was cured on my 2012 car by fitment of new starter motor. Apparently they are a known weakness on late 322s. Only Range Rovers since 1988
Post #476807 26th Apr 2018 11:17am
Frans@Yamorna
South Africa 2012 Range Rover Vogue SE TDV8 Zambezi Silver
Or maybe the start button?? 2012 TDV8 Vogue SE 4.4
Post #476820 26th Apr 2018 2:17pm
paul70
Thanks for the replies. Started tonight on first push but will get a starter ordered up.
Thanks
Paul
Post #476839 26th Apr 2018 4:59pm
paul70
A little confused as mentioned, it is said these starter motors are troublesome on later L322's RR's but some listings I'm seeing are showing same starter for both the 3.6 and 4.4 td v8. Is this the case? Don't want to remove the starter to find I've ordered the wrong one!
Many Thanks in advance
Paul.
Post #476844 26th Apr 2018 6:21pm
contact our site sponsor dan @ duckworths and he will make sure you get the right one... ... - .- -.
Post #476845 26th Apr 2018 6:24pm
