![]() | Home > Maintenance & Mods (L322) > rear windows |
stan Site Moderator Member Since: 13 Jul 2010 Location: a moderate moderated moderator moderating moderately in moderation Posts: 35765 ![]() ![]() |
do they operate ok from the rear switches ,if so it might be the front drivers switch pack thats faulty... ... - .- -.
TerryT-J Member Since: 02 Sep 2013 Location: Johnston, Pembrokeshire Posts: 86 ![]() ![]() ![]() |
I had the same problem. It was basically the lack of use! The glass was stuck in the rubber and was helped down. I used a little rubber grease in the window rubbers and seemed to do the trick. |
Balloonengineer Member Since: 03 Sep 2017 Location: Kent Posts: 180 ![]() ![]() ![]() |
The front and rear window switches create the same problem. Looking at the wiring diagram, (p37-39) the front set of switches operate the BCM, so bypass the rear switches, so perhaps that discounts the switches?
Before I greased the rubbers (ooerr missus) I could hear the window motors making a bumping sound so I’m assuming that was the anti trap kicking in when trying to wind them down. |
