Home > Technical (L322) > Resistors to slow flash on LED 2010 lights
Page 2 of 4 <1234>
Nickj
2003 Range Rover Vogue SE 4.4 V8 Java Black
Parallel didn't work when just doing the front. I've tried this. Should all indicators work independantly or would the fact i've not installed the back kit effect it?
What wattage did you use on yours oodathort?
The pic is what i'm afraid off!!
Post #47695 26th Jan 2011 8:22pm
oodathort
Hi yes you have to do both front and rear the wattage is not the issue its the resistance wattage is about the heat dissipation resistance is about fooling the lcm to think it has a incandesant lamp connected Porsche Cayenne
RR Sport TD6
Porsche 911sc
AM vanquish
AM Db7
AM DB7
Lotus Esprit V8
Lotus esprit V8
Lotus esprit V8
Lotus esprit 2,2 turbo
lotus espirit 2lt turbo
lotus excel
escort 16 i
capri 2.8i
lotus sunbeem
jenson interceptor
land rover series 1
MGBGT
MG Roadster
Post #47696 26th Jan 2011 8:27pm
nowt to do with voltage, its amps that the resisters pretend to be ..the ecu sends a voltage to the bulb and if it doesn't get the correct resistance back it puts up an error, hence the need for resisters if you have leds .....now it could be that the RR setup is different and somehow picks up on the positive only feed so putting a resister in series 'might' give the ecu the reading it needs..
if you put leds in that have a constant feed [like fogs etc] and not a pulse feed [like indicators] then resisters defo go in parallel.. ... - .- -.
Post #47698 26th Jan 2011 8:28pm
oodathort
correct hense my reply resistance is the key !!!! Porsche Cayenne
RR Sport TD6
Porsche 911sc
AM vanquish
AM Db7
AM DB7
Lotus Esprit V8
Lotus esprit V8
Lotus esprit V8
lotus excel
escort 16 i
capri 2.8i
lotus sunbeem
jenson interceptor
land rover series 1
MGBGT
MG Roadster
Post #47699 26th Jan 2011 8:34pm
Nickj
oodathort- you cant remember what colour wires the rear indicator live/ground were can you??
Might start by installing that kit first.
Post #47713 26th Jan 2011 9:30pm
oodathort
Hi ground is brown
idicator is blue/ yellow Porsche Cayenne
RR Sport TD6
Porsche 911sc
AM vanquish
AM Db7
AM DB7
Lotus Esprit V8
Lotus esprit V8
Lotus esprit V8
lotus excel
escort 16 i
capri 2.8i
lotus sunbeem
jenson interceptor
land rover series 1
MGBGT
MG Roadster
Post #47764 27th Jan 2011 7:59am
Nickj
Thanks. I have decided to get someone with some elec knowledge to sort it out (as i prob should of done in first place) so will update with results once done. Thanks for input/ comments.
Post #47890 27th Jan 2011 10:22pm
ogy
United Kingdom 2003 Range Rover Vogue Td6 Bonatti Grey
They need wiring in parallel and you must do all four corners. If your anywhere near yorkshire i will be happy to sort it for you for a few beer tokens! Heres my 03 working.
&feature=youtube_gdata_player
Post #47920 28th Jan 2011 9:26am
Nickj
Ogy, you've no idea how much i'd like to take you up on that offer but i think your 300 odd miles away!!
I might have another go myself if all resistors front and rear need to be wired as when i tried i only did the front and was expecting to see these work and when they didn't gave up!!
Post #47973 28th Jan 2011 3:57pm
nick, i thought you had done all four and had the problem..if you've only done the front two then when you do the rears it should be ok.. ... - .- -.
Post #47979 28th Jan 2011 4:18pm
Nickj
No, only front as thought they would work independantly. Will have to wait till next week now but will update with results.
Post #48018 28th Jan 2011 9:20pm
Thud ....that might be the problem solved [hopefully Wink ] ... - .- -.
Post #48020 28th Jan 2011 9:22pm
Nickj
While your there scarey and clearly a man of knowledge I've seen a blanket repair service for £150 for mk4 sat nav units. If i bought this
http://cgi.ebay.co.uk/ws/eBayISAPI.dll?Vie...TQ:GB:1123
and got it repaired would i have a cheap sat nav upgrade. Obviously don't know what £££ it will finish on but doubt it will be £££'s
Post #48021 28th Jan 2011 9:25pm
looks like the one nick, makes sense what you propose ....i'll see if i can find some info here..
edit... http://www.fullfatrr.com/forum/topic4418.html?highlight=dvd+nav theres a post [DAN's] that links to an ebay one thats identical to your link nick... ... - .- -.
Post #48024 28th Jan 2011 9:32pm
Nickj
From what i've read looks like straight swop and seem to go for £350+ so if it stays around this and use this
http://cgi.ebay.co.uk/BMW-E46-M3-E39-X5-MK...2a0d05fc21
could be a steal?
Post #48027 28th Jan 2011 9:37pm
Page 2 of 4 <1234>
