Home > Maintenance & Mods (L322) > LED globes
littlecub
Australia 2003 Range Rover HSE Td6 Epsom Green
LED globes
I have halogen globes and was thinking of putting in LED globes.
Has anyone done it and was it just plug and play as they ad says.
TIA
littlecub
Post #476986 28th Apr 2018 2:08am
p38arover
Australia
The halogen bulbs in the headlights or the reversing lights? Ron B. VK2OTC
2003 L322 V8 Auto
2007 Yamaha XJR1300
Post #476987 28th Apr 2018 2:12am
jaysta10k
United Kingdom 2014 Range Rover Vogue SE SDV8 Santorini Black
Yep did all mine and also replaced all the interior lights also makes a big difference looks much better. Range Rover Vogue SE 4.4 SDV8 SVO Stying Pack
Audi A4 2.7 TDI S Line Black Edition phantomn black
Previous Cars
Range Rover Vogue SE Overfinch Styling 22" Elara's full black stealth colour coded
Java black Range Rover sport 2.7 TDV6
Alaska white Range Rover sport overfinch 3.6 TDV8
BMW M3 Carbon Black
Post #477011 28th Apr 2018 10:20am
littlecub
Hi p38a,
In the headlights,but have read elsewhere that there not all that different than the night breaker globes that I normally use.
One which blew the other night... Censored
Post #477060 29th Apr 2018 12:53am
wayneg
Australia 2007 Range Rover Vogue SE TDV8 Java Black
I have h7 leds in the headlamps. Yes I know they allegedly melt the road, blind babies and are a menace to everyone else on the planet, however, I find no issues with them, in fact I think they are great. The problem fitting them like all exterior LED`s on the L322 is the bulb out warning sends a 2volt pulse to test the bulbs, not such a problem for your number plate bulbs but you cant go round flashing everyone with your headlamps every few minutes. I overcame this by fitting relays and load resistors to each lamp to fool the system and stop the 2volts reaching the bulb. A bit of effort but worth it.
If you only travel in the city I would not bother but if you go bush they light up the road better than any hid I have been behind. 2007 TDV8 VSE
2003 TD6 gone.
2002 P38a gone
1999 P38a gone
1997 p38a gone
1993 VSE gone
1992 VSE gone
1966 Series 2a with V8 conversion gone
Post #477095 29th Apr 2018 1:36pm
