![]() | Home > Technical (L322) > Help! Gasket cover change went wrong |
Pawl Member Since: 08 Nov 2017 Location: West Midlands Posts: 709 ![]() ![]() ![]() |
It might help if you can show a photo of your problem.
Jmckenzie295 Member Since: 18 Apr 2018 Location: Glasgow Posts: 17 ![]() ![]() ![]() |
Apologies,.
stan Site Moderator Member Since: 13 Jul 2010 Location: a moderate moderated moderator moderating moderately in moderation Posts: 35771 ![]() ![]() |
PaulTyrer Member Since: 22 Jul 2013 Location: Devizes, Wiltshire Posts: 1262 ![]() ![]() ![]() |
Suggest a stud extractor? |
Paul thornton Member Since: 23 Sep 2017 Location: Lancashire Posts: 545 ![]() ![]() |
Long nose mole grips? |
Doonhamer Member Since: 07 Jul 2017 Location: Thatcham, Berkshire Posts: 209 ![]() ![]() ![]() |
Have you got a couple of nuts of the same thread as the screw? You could try locking them together on the thread and then use a spanner on the lower nut to undo it - that often works. L322 TDV8 4.4 - current
What about one of those induction heater thingy's that Fuzz Townsend uses on Car Sosage? |
b348xyx Member Since: 29 Sep 2016 Location: Kent Posts: 319 ![]() ![]() ![]() |
for that, mole grips should do it no issue.. 2003 Range Rover 4.4 Litre V8 - Adriatic blue
It wasn't twisting at first. But eventually got it with the mole grips.
All sorted, well one half done. Found a pipe that cracked and came off when starting, breather hose. So replaced and working fine.
