Home > Technical (L322) > TD6 no start fuel pressure issue
Motobox
United Kingdom 2004 Range Rover Vogue Td6 Galway Green
Hi all. I bought my 04 TD6 as a non runner, so expected a bit of work. Athough there's more than I anticipated!
So far:
I've removed the HP pump and removed the nozzle to find the o-ring and spacer split. I've replaced them, the outer ring and gasket. Nothing changed!
I couldn't connect to the ECM, so I was working blind and getting frustrated. I bought allcomms and cleared out all the faults I could. I can now communicate with the ECM. Codes below.
The battery died before I could get cranking pressure. Static low pressure is 2.5 bar, with high pressure reading 0. Also it won't start with a puff of easy start.
ECM codes
1260 fuel pressure control
3515 air conditioning output????
1190 fuel rail plausibility
Glow plug device or relay
I thought I'd checked all the relays? All the fuses are good.
Any advice would be great.
Post #477232 30th Apr 2018 8:02pm
Nick Evans
You should have 3.5 - 4 bar on the low pressure side with just the ignition on, low pressure could be down to a failing low pressure pump/blocked filter or leaking injector.
Post #477237 30th Apr 2018 9:00pm
Motobox
Service history suggests the filter was last changed about 20k ago. I'll put a new one on and see if there's a difference.
Post #477239 30th Apr 2018 9:13pm
bembo449
United Kingdom 2002 Range Rover Vogue Td6 Adriatic Blue
right , I happened to be at my mates garage y.day where they had a non stating 04 FF on the ramp , after checking the fuel pressure at the rail ( 1 bar) they renewed the leccy pump under the rear pass door , no change , then checked the in tank pump pressure and found it was ok , somewhere near the leccy pump there is a T piece which they think has some type of valve in it ? took that out of the set up and it fired straight up , not saying this is your fault but I thought I would suggest it if you find the pumps are all doing what they should pal
Post #477317 1st May 2018 9:47pm
Motobox
Thanks for the tip. It's the quirky things like that spin your head. I ordered a new inline,as it's easier than faffing around with flow rates. The diesel pump guy said 3.5 bar up is where I need to be.
Post #477323 1st May 2018 10:32pm
wayneg
Australia 2007 Range Rover Vogue SE TDV8 Java Black
I have just had problems with the fuel supply, turned out to be the low-pressure pump even though I was getting 4bar pressure from the sensor ontop the fuel filter. This video might be of interest, the guy is using BMW IPNA diagnostics at 1st.
https://www.youtube.com/watch?v=TL_moF4zyAY 2007 TDV8 VSE
2003 TD6 gone.
2002 P38a gone
1999 P38a gone
1997 p38a gone
1993 VSE gone
1992 VSE gone
1966 Series 2a with V8 conversion gone
Post #477328 2nd May 2018 12:41am
