![]() | Home > Technical (L322) > Door Card Rattle |
| stan Site Moderator Member Since: 13 Jul 2010 Location: a moderate moderated moderator moderating moderately in moderation Posts: 35874
if you have 20 inch wheels on then thats the reason...the td6 wasnt designed to run these size wheels hence the vibrations..
| tomh Member Since: 30 Jan 2018 Location: Cheshire Posts: 7
Thanks Stan, I bought the car with the original 18/19" (?) alloys and recently swapped to new 20" alloys however its always had the rattle, I don't think swapping them has changed it at all.
| Sandyt Member Since: 07 Nov 2013 Location: Wraysbury Windsor Posts: 2286
From memory there is a connector situated top front that needs to be either tied or glued down and if not it rattles or it did on mine - hope it is that as an easy fix |
