![]() | Home > Technical (L322) > Lots of faults modules not communicating |
| northernmonkeyjones Member Since: 24 Mar 2012 Location: derby Posts: 8787
Try a battery reset.
| Motobox Member Since: 30 Apr 2018 Location: Northampton Posts: 6
Get the battery tested (foc) at any fast fit place. Although it starts, it can still be leaving the building.
| foptics Member Since: 15 Apr 2018 Location: Pontefract Posts: 9
Thank you the people who have responded.
| Grofus Member Since: 24 Mar 2017 Location: Co Clare Posts: 577
Your battery is on the way out and most likely the cause of the problems. The modules rely on data from each other and that needs a constant good voltage.
Battery debate....
Just wondering which battery as some web site like Yuasa, halfrauds & also listed on Varta web site are AGm batteries, stop/ start in other words.
The charging circuit on your FF is not designed to charge an AGM battery so you won't get the benefit of it. AGM battery's are standard fitment from 2010. 2007 Vogue TDV8 in Zermatt Silver with Charcoal |
| mpirie Member Since: 26 Jun 2012 Location: In the Highlands Posts: 912
Remember, batteries purchased from ECP usually carry a long guarantee period, and will be replaced free of charge!
| uzp315 Member Since: 19 Nov 2017 Posts: 428 |
I read in the sailors maintenence bible a few years back that once a battery is down to even 12v it needs replacing. Less than 11v and this is serious. Mine was down to 9v last week and I have had a wild array of electrical glitches. I left it on an overnight conditioner and am going to see if I can bring it back to life.
Try to avoid Bosch S4 and S3, get the S5.
Hi everyone
I can recommend this as it gives great power without having to mess about trying to fit the 020 size.
http://www.fullfatrr.com/forum/topic35207.html
HI Guys
