![]() | Home > Maintenance & Mods (L322) > Tyre presssures? |
stan Site Moderator Member Since: 13 Jul 2010 Location: a moderate moderated moderator moderating moderately in moderation Posts: 35766 ![]() ![]() |
thats not an OE size so trial and error..i would start at 34 psi. |
bogie Member Since: 06 Nov 2010 Location: Notts/Sth Yorks/Lincs border Posts: 208 ![]() ![]() ![]() |
yeah, its easy for OE tyres as its on the sticker inside the door jamb on most cars
Incorrect differential in tyre pressures between front and rear will lead to premature center diff failure |
V8 VOGUE Member Since: 26 Sep 2010 Location: bristol Posts: 31 ![]() ![]() |
I dont want OE pressure!!! |
you've got some suggestions |
What make are the tyres .........
Dixy Member Since: 09 Apr 2009 Location: Somerset Posts: 1110 ![]() ![]() |
Why? letters not necessarily in the right order |
I use lower pressures in Winter Conditions and higher when on high speed motorway work. The Door Jam Pressures are only there to ensure LR do not get sued and are bit on the high side IMHO. |
Because the transmission is designed to allow a certain amount of slippage. If you've changed the rolling radius of the tyres (specifically the front rather than the rear or vise-versa) then one axle's wheels will be travelling faster than the other. The same principle applies left to right and can cause front/rear diff failure quite quickly too. This is why the fronts are X and the rears are Y rather than the same all round. Also why different pressures are given for different loadings as this also changes the rolling radius. In the L322 incorrect front/rear pressures usually manifests itself as vibration felt at speed, similar to wheels being out of balance. The Workshop Manual also makes speciffic reference to the tyres being at the correct pressures to maintain correct operation of the EAS. ![]() |
RRUK Site Supporter Member Since: 08 Jun 2007 Location: UK Posts: 6374 ![]() ![]() ![]() |
My advice: get a nice set of OE LR 20" alloys and Tyres and then you can refer to the sticker on the OSF door pillar for pressures and bonus feature, it won't screw up your transmission and you won't look blinged but cool. |
They are yokohama, somebody must know exact pressure
I think judging by the lack of answers no-one knows.
let your mate tell you then..
nbunney Member Since: 10 Aug 2008 Location: Lancashire Posts: 2067 ![]() ![]() ![]() |
Overfinch / K |
