Home > Technical (L322) > Anybody know what this could be ? (L322 2006 TDV8)
Pawl
England 2007 Range Rover Vogue TDV8 Cairns Blue
Anyone have any ideas what this is & what it should be connected to ?
While installing dashcam hard wiring to the passenger fuseboard, this item fell down from the fuseboard area onto the carpet in the passenger footwell.
It looks almost like a very lightweight, partially insulated flexible earth strap - but obviously I can't see what the original connections are like as it it's either fatigued through or been torn out & I can't see any of the connections on the fuseboard without taking a lot of trim out..
The strap is about 8mm wide & 40mm long.
The engine still runs & there's no obvious faults so I'm not sure if it was previously just loose under the fuseboard or if I've somehow dislodged it - although no force was required to feed a cable through behind the fuseboard.
 Paul,
2001 Discovery 2 TD5, 211,000 miles & climbing
2006 FFRR TDV8 Vogue 151,000 miles & now sold
Member of Midland (Land) Rover Owners Club, www.mroc.co.uk
Post #477642 6th May 2018 7:26pm
maybe it originated from the glovebox and made its way to the fuse box?? if so it could be anything. ... - .- -.
Post #477645 6th May 2018 8:11pm
Pawl
Stan,
I don't think it was in the glovebox - it dropped when I was moving the trim panel under the fusebox ( the one above the passengers feet)
I also found a 15A fuse that had been dropped at some time. That was definitely resting on the trim. Paul,
Post #477646 6th May 2018 8:40pm
Paul thornton
It's for the heated windscreen.
Does it still work? Maybe it's an old one if the screen has been replaced.
Post #477651 6th May 2018 9:34pm
Pawl
Paul,
Thanks for the info.
It was working a couple of months ago.
But I'll check in the morning.
Where I was working was a long way below the screen, so hopefully I can't have knocked it off. Paul,
Post #477654 6th May 2018 9:56pm
Paul thornton
One end of it is bonded to the windscreen and the other should have a connector on which plugs into the wiring on either side of the A pillar so doubtful it would just fall off. My guess is it's from a previous windscreen and the fitters just cut it off as they were removing it.
Post #477657 6th May 2018 10:25pm
