Home > Technical (L322) > 2004 Vogue Glovebox Latch question
Knightrider
Hi the glovebox lid on my car recently broke so I decided to get a replacement and exchange it. When taking the old one out I had to remove the wire from the latch and a spring popped out but now I'm not sure where it goes so I was hoping someone might know where to fit it. I've added a couple of photos of the latch and I've put the spring where I think it should go - this is before I attach the latch wire back onto it. Can anyone tell me if this is the correct location?
Also I lost the original Spring so found a similar sized one from a biro pen as a replacement, does anyone know from previous experience if thay will be ok or cause problems?
 2004 Range Rover Vogue 4.4 v8 LPG, Java Black, 22' Hawke Alloys, Black Beast
Post #477690 7th May 2018 6:44pm
bebechoon
France
Weegie had this problem on his previous Fatty and he helpfully wrote up how he resolved the issue:
http://www.fullfatrr.com/forum/topic35305.html
Unfortunately the photo has since gone. Maybe if you PM him he'll be able to give you more info?
 It's "bébéchoon", ackcherly, with accents. 'Steve' to my chums.
20 years ownership of Solihull products, ALL GONE NOW, sniff!
Current motor: Suzuki S-Cross 4WD auto, 1.4 petrol. Oh so reliable! 7 years now and no problems. Oh, all right then, a leaking shocker replaced under guarantee.
Previous:
TD6 HSE L322 Auto FF
2.5 TDi 4-door Classic
Disco II
And my 1st Rangie: in 1995, a 2-door VM 2.5 diesel Classic
Not to mention the Lada Niva before those. (I said not to mention it!)
Post #477749 8th May 2018 3:09pm
Weegie
Found the photo:
Just wound the spring onto the cable in that position. No fiddling to get it into place and works perfectly well. Thumbs Up John
GAP iiD BT-Sold
Post #477763 8th May 2018 5:36pm
Knightrider
Thanks for that, winding the spring onto the cable does sound like it will be easier than trying to fiddle it into the slot under the cable 2004 Range Rover Vogue 4.4 v8 LPG, Java Black, 22' Hawke Alloys, Black Beast
Post #477790 8th May 2018 11:34pm
