![]() | Home > Technical (L322) > AMK Compressor - Error and Questions |
MikeO Member Since: 02 Jan 2018 Location: The Cotswolds Posts: 546 ![]() ![]() ![]() |
I'm not sure I can be of much help but I had a similar issue with my D3 and posted a thread on disco3: https://disco3.co.uk/forum/help-suspension...21291.html
muddycharles Member Since: 05 May 2011 Location: Miami, FL Posts: 95 ![]() ![]() ![]() |
The mechanic had flashed the compressor with the wrong firmware. Reflashed to AMK and now all is fine. 2008 HSE B. Grey
PilotTerry Member Since: 05 Oct 2019 Location: SoCal US Posts: 4 ![]() ![]() ![]() |
Hey MuddyCharles - this is good info! - I'm doing this swap from Hitachi to AMK now and I want to be sure the system is flashed with the right software update, Thank you! 2006 RR HSE, 4.4, 115k Miles, Rimini Red |
I used IID Gap tool to flash the new firmware (at the time it did not work 100% as I could not lock the suspension in access mode - took about 6 months of back and forth to figure out it was firmware then updated about 4 months ago) - the new firmware works flawlessly. 2008 HSE B. Grey
Mile High RRSC Member Since: 23 Aug 2023 Location: Colorado Posts: 3 ![]() ![]() ![]() |
Hi MuddyCharles,
This was my problem. There are two - one for AMK and one for Hitachi (I think). If you flash the wrong one (as I did several times) the behavior of the compressor is not correct - but it will still work.
