Home > Wheels & Tyres > 255/50r20 to 265/50r20? ok to add a little width?
Page 3 of 5 <12345>
bob-lad
And as mentioned earlier in the thread the 255/55 have the tallest sidewall which not only helps smooth out pot holes, it should help keep the kerbing fairy at bay.
Post #478027 11th May 2018 1:53pm
Vogue
Agreed re speedo readings - my last L322 was out by 3mph at 100 = 3%.
The only other thing to be aware of is that larger diameter tyres will increase your gearing, the result is more MPG on motorways etc, but it will also reduce your acceleration and result in more gear changes / hunting for gears - which will increase fuel consumption on some types of roads and when towing. 2021 L405 Vogue SE 4.4 V8 DIESEL ~ #17
Post #478044 11th May 2018 4:38pm
Grofus
Ireland 2007 Range Rover Vogue TDV8 Zermatt Silver
Yeah, others have had those issues but I haven't and I tow a fair bit. 2007 Vogue TDV8 in Zermatt Silver with Charcoal
Post #478075 11th May 2018 8:00pm
dolph34
Ireland 2015 Range Rover Autobiography SDV8 Corris Grey
Just put 255/55/20 On my 4.4 tdv8 and it doesn't make any difference to the gearbox but on my 3.6 with the same size tyres , it would hold onto a lower gear at low speeds ( 60kph) but it was hardly noticeable. 2015 4.4 AB
GSXR 1000 K5
R1 1998
Post #478078 11th May 2018 8:29pm
GGDR
Quote:
255/55 have the tallest sidewall ....should help keep the kerbing fairy at bay.
not finding the 255s protect the rim in any way. hence looking at 265 or 275s
. Cheers, Greg
Post #478085 11th May 2018 8:49pm
paulbrown22
United Kingdom 2011 Range Rover Supercharged 5.0 SC V8 Stornoway Grey
Some closer pictures of 275/45/r20 I took on the way to work this morning.
Post #478095 11th May 2018 10:00pm
just to stir things up a bit more Greg, i had 295/45/20 tyres on RRS 9.5j rims on my old td6..
Post #478096 11th May 2018 10:08pm
dolph34
Those wheels are lovely 2015 4.4 AB
GSXR 1000 K5
R1 1998
Post #478098 11th May 2018 10:24pm
Gotta like those multi spikes esp in gunmetal, for comparison these have 255/50
 There is nothing that can't be fixed with a hammer😜😜
Post #478189 12th May 2018 8:57pm
GGDR
Paul and Mark and Me lined up here for 'arch fill' scrutiny!
Paul I lowered yours into access mode, hope you don't mind!
Not much in it but the 275s are a tiny bit lower . The website Rob posted says there's a 7.5mm difference in the diameter:
255/50r20 diam=763mm original
275/45r20 diam=755.5mm
I think the side view is not the only factor though. The 275s will probably make up for it with a wider stance whoh would be visible from most other viewing angles.
Paul do you fancy posting up some different angles? Thumbs Up
. Cheers, Greg
Post #478193 12th May 2018 10:40pm
Rob99
You could also lower the suspension settings permanently with IID tool if you wanted a smaller gap between tyre and wheel arch.
Think Stan's lowered his by about 15mm although he has 21" wheels on his. 2021 D350 Fifty Edition - Carpathian Grey
2017 4.4 SDV8 Autobiography (2021-2024) - Santorini Black
2012 4.4 TDV8 Westminster (2016-2021) - Santorini Black
Post #478196 12th May 2018 11:00pm
paulbrown22
Greg - sure, I have the RR with me in Poole this weekend, will take some photos with different angles in the morning!
This thread has definitely made me more closely admire the tyres on other FFRR's now. The TUC march in London today meant my normal 45min journey across took 2 hours 10 mins, so plenty of time and opportunities for tyre spotting Smile.
Everything I saw this morning was running standard 255/50r20 tyres, which from a side view I didn't think looked overly different to my 275/45r20's.
Post #478199 13th May 2018 12:02am
Grofus
255/ 55 sidewall is taller than standard 255/ 50 by. 12.75 mm and do better protect the rims. Also all terrain tyres have a deeper tread, normally 10mm. That's what I have fitted and no kerbing worries for me. Thumbs Up 2007 Vogue TDV8 in Zermatt Silver with Charcoal
Post #478200 13th May 2018 12:20am
GGDR
that small gap under the blue line on Paul's 275s is 3.75mm
Kind weird such a small amount would be even noticeable but my blue guidelines show it up.
Rob - Thumbs Up If that gnat 3.75mm bothers that's a good idea to close the gap a little.
Grofus I haven't looked at 255/55 vs 255/50 yet. Post up a side view of yours? I'm well used to it but there's a certain pressure of London traffic / parallel parking you want/need to get into spaces asap and the weight of the car even it idle rolling speed the can push the rim into the kerb as soon as the tyres touch the stone. So I really want the width over sidewall height but I'll check out the 55 vs 50.
Paul cheers that would be great.
Anyone else out there running the Uniroyals Paul has? They look very good to me.
. Cheers, Greg
Post #478203 13th May 2018 6:47am
Vogue
If you are that worried why not just go 285/50/20 - i’ve got a set of those in Cooper AT3 for the shooting season as well as the 22” Turbines on 275/40/22. You have then got both width and tyre wall height 2021 L405 Vogue SE 4.4 V8 DIESEL ~ #17
Post #478221 13th May 2018 9:04am
Page 3 of 5 <12345>
